ONKYO TX-NR616 7.2 receiver setup with one PSW10
I have an Onkyo TX-NR616 7.2 receiver and want to setup my Polk PSW10 with it. Can I use my .2 sub outputs to each l+r line in or would I use one sub output and a Y cable or just 1 sub out to the l or r line in. Also please tell me what the settings on the back should be. I want the receiver settings to handle the output so I want to disable the sub's crossover. I think the low-pass filter should be set to the highest setting (is this correct?)
  • jeremymarcinko
    The crossover point really depends on the size of the other speakers in the mix. Just use a single subwoofer cable from the 616 to the psw10, either L or R. The subs amp is a mono amp so their would be no benefit of delivering the same signal twice.
  • marktherob2011
    thank you
  • D'prived
    D'prived Posts: 191
    Set the crossover knob to the highest setting. This disables the crossover in the sub and lets the receiver decide where the crossover should be.
