AC outlet on receiver
edited August 2004 in Electronics
can I use one of the ac outlets on the receiver to either power a cd player or my extra dvd player which will be used for MP3's.
I have no other room on my power bar or in the wall. I can either plug it into the receiver or hook up a mutli-plug on the wall which will then feed the power bar the tv and the cd player what would be the best option ??
Post edited by Willow on
Welcome!
    edited August 2004
    some purists might say no, but with a dvd or cd playr, you shoulnt have a problem because they dont use much juice. however, avoid higher power usage items being plugged in there, such as any power amps. power amps should have their own power supply
    but plugging a cd player or dvd player in their should not be a problem if you have no other options.
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
    edited August 2004
    thank you it's pretty much what I thought !! yeah there is no way I would hook up an amp or sub in the AV outlet.
    Thanks again !!
    edited August 2004
    I more or less solved the outlet crunch by plugging in 2 power strips to the wall which gave me 10 outlets.
    edited August 2004
    that's another option as well just adds more clutter behind the TV area
    edited August 2004
    I just picked up the new Monster power bar. It's called the HTS2000 MK II. 12 outlets on this bad boy!! 2 high current outlets for your receiver and main amp. Pretty nifty.
    Here's the info
    I got mine a little cheaper than MSRP at one of the sub stores at Amazon.
    I like it...
    edited August 2004
    very nice but those puppies are 350-400 cad......try and explain that to my wife !!
    edited August 2004
    I have a product called the VEI V-8000 power pannel. It has 8 individually switched outlets. I plug my 7 amps into it and it works great. I then plug the VEI and another more standard power strip into my power conditioner. This seems to work out really well. A power conditioner for each piece would be better but is out of my price range. The cost of the VEI unit is +- $69.00. Mama didn't have a fit over that one. The 7 amps were the tough sell.
    Phil
    edited August 2004
    I bet they were. Losta dirty dishes there...;)
    Willow, I'm sorry, I didn't notice your in Canada.:(
    edited August 2004
    But they sure sound good driving the 1.2s in front, 2.3s in the rear, the pair of cs400is in the center and the sure sub. Life is good and I do most of the cooking so I don't have to do too many dishes.
    Phil
    edited August 2004
    never see dirty dishes thats what the dishwasher is for !!
    No prob...yes I am in land of beavers and tim horton's
    edited August 2004
    GO LEAFS!!!!:D
    "she had the body of Venus, with arms."
    edited August 2004
    wrong city for me !!
    Sens fan here
    edited August 2004
    Sens??? Always the bridesmaid...never the bride:D
    wait a minute...same about the Leafies too!!:eek:
    Maybe we need to pick diff teams Willow??:confused:
    edited August 2004
    seems that way !! maybe we should go to an american team composed of alot of canadians.....
    edited August 2004
    wouldn't that be EVERY team?????
Welcome!
Welcome!
