AC outlet on receiver
Willow
Willow Posts: 11,232
edited August 2004 in Electronics
can I use one of the ac outlets on the receiver to either power a cd player or my extra dvd player which will be used for MP3's.
I have no other room on my power bar or in the wall. I can either plug it into the receiver or hook up a mutli-plug on the wall which will then feed the power bar the tv and the cd player what would be the best option ??
Post edited by Willow on
  • ohskigod
    ohskigod Posts: 6,505
    edited August 2004
    some purists might say no, but with a dvd or cd playr, you shoulnt have a problem because they dont use much juice. however, avoid higher power usage items being plugged in there, such as any power amps. power amps should have their own power supply
    but plugging a cd player or dvd player in their should not be a problem if you have no other options.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • Willow
    edited August 2004
    thank you it's pretty much what I thought !! yeah there is no way I would hook up an amp or sub in the AV outlet.
    Thanks again !!
  • cfrizz
    cfrizz Posts: 13,415
    edited August 2004
    I more or less solved the outlet crunch by plugging in 2 power strips to the wall which gave me 10 outlets.
  • Willow
    edited August 2004
    that's another option as well just adds more clutter behind the TV area
  • amulford
    amulford Posts: 5,020
    edited August 2004
    I just picked up the new Monster power bar. It's called the HTS2000 MK II. 12 outlets on this bad boy!! 2 high current outlets for your receiver and main amp. Pretty nifty.
    Here's the info
    I got mine a little cheaper than MSRP at one of the sub stores at Amazon.
    I like it...
  • Willow
    edited August 2004
    very nice but those puppies are 350-400 cad......try and explain that to my wife !!
  • Phil Dawson
    Phil Dawson Posts: 288
    edited August 2004
    I have a product called the VEI V-8000 power pannel. It has 8 individually switched outlets. I plug my 7 amps into it and it works great. I then plug the VEI and another more standard power strip into my power conditioner. This seems to work out really well. A power conditioner for each piece would be better but is out of my price range. The cost of the VEI unit is +- $69.00. Mama didn't have a fit over that one. The 7 amps were the tough sell.
    Phil
  • amulford
    edited August 2004
    I bet they were. Losta dirty dishes there...;)
    Willow, I'm sorry, I didn't notice your in Canada.:(
  • Phil Dawson
    edited August 2004
    But they sure sound good driving the 1.2s in front, 2.3s in the rear, the pair of cs400is in the center and the sure sub. Life is good and I do most of the cooking so I don't have to do too many dishes.
    Phil
  • Willow
    edited August 2004
    never see dirty dishes thats what the dishwasher is for !!
    No prob...yes I am in land of beavers and tim horton's
  • ninerbj
    ninerbj Posts: 870
    edited August 2004
    GO LEAFS!!!!:D
    "she had the body of Venus, with arms."
  • Willow
    edited August 2004
    wrong city for me !!
    Sens fan here
  • ninerbj
    ninerbj Posts: 870
    edited August 2004
    Sens??? Always the bridesmaid...never the bride:D
    wait a minute...same about the Leafies too!!:eek:
    Maybe we need to pick diff teams Willow??:confused:
  • Willow
    edited August 2004
    seems that way !! maybe we should go to an american team composed of alot of canadians.....
  • ninerbj
    ninerbj Posts: 870
    edited August 2004
    wouldn't that be EVERY team?????
