Long delay between songs in Pandora
shaybloch
I experience long delay between each song. It's around 10sec of silent.
If I'm playing directly from the pandora app or from any other device I don't have the delay.
It's pretty noticeable, Especially when you have friends over. The delay is really long.
Any solution for that problem?
I have Pandora playing through the Polk Omni app and no delay at all.
Not sure why you are having the delay. -
Same thing happens to me from time to time when using my squeeze box (wireless connection ?)“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain
Sounds like a buffering issue.
That's what happens to me most of the time, but here's a wired one if I'm streaming to the squeezebox (again wireless) from any source i.e. pandora, my server etc.. and use the microwave it will lockup the squeezebox until it's done. Then every once in awhile I have to do a reset to get the squeezebox working again. I think I need to run some cat5 out to it.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain
