To EQ or not to EQ
You can all see my set up, my new Marantz doesn't have a very good musical EQ built in. Should i buy a new EQ? Are there any new fangledy EQ's out there?
B&W CM10 Mains, Monitor 40 Surrounds, B&W Cm Centre, PSW 125 sub/ CV 10" sub, Marantz 7701 Processor, Carver M4.0T, Carver 705x 5 channel, 60'' Sharp LED, Xbox One, Xbox 360, Sonos, and of course my trusty laptop for hi res ( for now)
    pitdogg2 Posts: 26,992
    we don't need no stinkin EQ...might just be the speakers you're using. I do not know that series very well, but I have sat and listened to other upper B&W's and they have all been very sterile to my ears. That being said the last time I sat and listened to some B&W's I had the wife and she is no audiophile yet commented on the very thing I dislike about them.
    tonyb Posts: 33,069
    Most don't use equalizers anymore....mainly because of the noise introduced into the signal. You can find many equalizers on your local craigslist or goodwill store for 10 bucks though....if that's your poison.
  • ^^^ what he said. I bought a couple different ones for diff reasons and eventually
    sold them off. $10.00-$30.00 for the experiment.
    The tweeters on those mains remind me of my RS super tweeters. :)
  • lmao, im sure its my inferior Bowers and Wilkins mains....That costed 4000 dollars. Thanks for your useless and offensive input. I usually get very constructive comments from this site.
    F1nut Posts: 51,722
    Cost has nothing to do with it.
    I have to agree with the stated sound signature of B&W speakers. Some like it, some don't. That you feel the need for EQ indicates there are aspects of that sound signature that you don't like.
    edited December 2014
    It is called synergy and it does take quite a bit to find it in the sweet spot. IF you equate dollars with high quality you could be very disappointed in the long run as I have sat and tried to like many upper dollar items. I came away less than impressed more times than not. I wasn't slamming your "Bowers and Wilkins" and I was giving constructive input. Have you tried other speakers with you set up? If yes do you get the same? My honest opinion is that adding an EQ will do more harm than good. Try different cables, speaker wires or heck even a new pre. Although that pre tends to be on the warm side. So what is it you mean when you say "musical" I know what I mean but your meaning might be way different.
    tonyb Posts: 33,069
    Webb_03 wrote: »
    So...just because they are B&W's costing 4g's....that's a guarantee of good sound ? Wow...
    Anyway, speakers are just part of the equation, it's the whole systems synergy that's required to come together. Most would agree anyway, the B&W sound is all sizzle and thump...can't say that truthfully to all their speakers but a lot of them anyway. Putting an equalizer though on 4g speakers....nobody does that anymore. Something else is lacking in your system or cables that has you thinking about equalizers.
    If an equalizer is what makes you happy though, many can be found cheap pretty much anywhere.....and know why they are so cheap ? Because nobody uses them anymore.lol
  • gimpod
    gimpod Posts: 1,793
    ZLTFUL wrote: »
    Adding an offboard EQ into the mix is just going to add more circuits to the signal path which always leads to more noise in that signal path.
    Fixed it for ya, Webb you can basically ask the same question in as many threads as you want but don't expect a different answer.
    forum.polkaudio.com/discussion/165025/marantz-7701-need-help
    I think you already know the answer and you my not like it, The Marantz it was the last thing you changed. It may just not play nice with what gear you've got.
    F1nut Posts: 51,722
    ZLTFUL wrote: »
    But Jesse...he paid $4000!!!!
    Slight correction, Ryan. They COSTED 4000 dollars.
  • gimpod
    gimpod Posts: 1,793
    ZLTFUL wrote: »
    LOL, I missed that, kids now days. We are so screwed! :'(
  • Webb_03
    Webb_03 Posts: 42
    I personally love the sound of bowers speakers, i listened to a LOT of speakers before landing on these. Sorry to hurt all you audio snobs' feelings. Ill try a different forum. Thank you to the people that offered helpful information.
    F1nut Posts: 51,722
    gimpod wrote: »
    A very valid point. What's interesting there is the Marantz house sound is indeed very musical.
    tonyb Posts: 33,069
    So then whats the bottom line here then ? You bought a pre/pro you thought you'd like...never heard before...and when you hooked it up you found it's sound not to your liking.
    Yeah...so, not like any of us has never bought a piece we didn't like. So whats the big beef then ? We already asked you questions to help you but you haven't answered. I'll bet you probably didn't even read the manual to the Marantz...see which settings you can adjust to tailor the sound. What other help are you seeking ? List your other gear and cables and maybe we can help you match stuff up better to your speakers. Other than that, not much else we can do for you.
    F1nut Posts: 51,722
    You can lead a horse to water, but.......
    tonyb Posts: 33,069
    lmao.....your affliction for old sayings rival my own. Love it....
  • ken brydson
    ken brydson Posts: 8,996
    Then you sneak up behind them and **** the **** . Wait, what??
    I have a couple of EQs in the fold; an old Sansui and a Pioneer (both from the vintage age and both "free", given to me-"here take this too!"). I use the Sansui to get a little more BASS out of the B.A. A200s rather than use a SUB. A200s need some breathing room and I just don't have that space in the room they're in, so EQs can work. Sure the bass will not be what I would get in the RIGHT room with no EQ but since I'm not EQing upper frequencies the extra noise is not really that noticeable. Plus you can TURN OFF the EQ and use a pass through when you want.
    Eventually, I'll move and find the right space and dispense with the EQ, but for now?
    B&Ws? Who knows? I suppose toning down those HIGHS would NOT be a bad thing. I really dislike those! YMMV
    cnh
  • Msabot1
    Msabot1 Posts: 2,098
    Audio Snobs??? Gotta love that one!!!
  • I snoot in your general direction.
  • Cnh, thanks for ur input. I was kinda planning on being able to cut the eq out for movies and such. It's what I'm leaning towards. The rest of you can go back under the bridge from wence you came.
  • Msabot1
    Come to think of it....I have caught some mighty big fish under bridges....
    F1nut Posts: 51,722
    That wence must not have costed much since it's missing something.
  • I find his wence sounding thin and sterile on the h.
    treitz3 Posts: 19,966
    That's it. You guys just need to stop giving solid audio advice. It offends the folks that don't want to hear it.
    ...."costed"..... Too much. *chuckles quietly*
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    I think that the problem may be with the use of monitor40's as surrounds. I haven't heard the B&W's but I would assume the sound signature is quite different. The auto eq will try to eq all of the speakers to a predetermined curve, but I have also read that adjustments are also made to create a seamless sound stage. Therefore the overall effect is limited to the capabilities of the least capable speaker, in this case in one of a different series. I would rerun audysssey with the surrounds unhooked to see if it makes a difference, if it does than you may consider upgrading them. Also I wouldn't be mixing a Polk psw125 with a Cerwin Vega 10"sub, that can't sound good. I wouldn't use the CV altogether.
  • Ha ha, my apologies. I don't give a damn for the op one way or the other. I figured I would offer some advice for the next guy that doesn't like the sound of his speakers that costed $4,000. Don't pair them with surrounds that costed $100 and a Cerwin Vega sub.
  • sucks2beme
    sucks2beme Posts: 5,682
    EQ can help, but it really doesn't fix problems.
    I use Fubar as my music software with the advanced EQ plugin.
    Much better than any hard EQ option. Still, EQ only can tweek
    the sound a little. If you don't like the way the speakers play with
    the amp, time for a change. I've had any number of people tell me
    that you can make any headphone sound the same with EQ.
    They are dead wrong. If there's a problem with the sound of a headphone,
    you can reduce the issue, but the sound signature stays the same.
    Speakers are even tougher. Audio snobs? Yup. Doesn't mean that we are wrong, though. You can continue hoping someone can suggest a magic cure.
    Or listen and learn. Been there, done that.
  • gimpod
    gimpod Posts: 1,793
    The real question is if your going to use an EQ ( :cry: )
    will it be a Graphic (not as many buttons/sliders)
    or a Parametric (Lot's of cool looking buttons/sliders)
    txcoastal1 Posts: 13,505
    I have EQ'ed music using JRiver's EQ UI to improve usually hot, and poor recordings...Tweeks that should have been done during the mastering
  • Msabot1
    Isn't that like covering up a bad case of BO with Old Spice??...it just does not work...if you start with garbage...the end result is garbage...
