LSi9 - low level listening?
Hey folks.
Just wondering how the LSi9 does at low volume levels? I do like to listen quietly, in my smallish room, and I'm curious to know how the LSi9's would do when played in this way. Do they need some more serious power going through them to bring them to life?
Thanks!
  • Mikey081057
    Mikey081057 Posts: 7,127
    They really like power but the 7's sound better at low vols...
    Garage | Polk Monitor 5B's
  • Bigerik
    Bigerik Posts: 149
    I've got plenty of power and current, so I am not worried there.
    Are you saying the 7's need plenty of power or the 9's? I figured they both did. :)
  • Mikey081057
    The 7's are easy to drive compared to the 9's I have had them (7's) connected to my 5 watt tube amp in a small room and they were fine.
  • Bigerik
    Bigerik Posts: 149
    So the extra bass of the second driver doesn't really add much until higher listening levels?
    F1nut Posts: 51,899
    Bigerik wrote: »
    I think it it adds bass regardless.
  • Bigerik
    Bigerik Posts: 149
    Which would make you think the 9 would do better at low volumes. All else being the same.
    F1nut Posts: 51,899
    Erik, any speaker that is capable of lower bass will produce lower bass at any volume level.
