Best Center Channel match for LSi7's?
Just upgraded my HiFi setup from the LSi7 to LSiM703. Going to use the 7's in my Home Theater setup, but need to add a properly matched center channel for the 7's. Any suggestions?
HiFi Setup: Luxman L-100U and T-110, Pioneer PL-516, Sony DVP-NS57P, Polk LSiM703, Polk DSW Pro 440wi
Home Theater Setup: Onkyo TX-NR709, Polk LSi7, Polk LSiC, AR Sub
That would be the LsiC.Front - Polk LSiM 705, Center - Polk LSiM 704c, Rear - Polk LSi 7
Subwoofer - Epik Legend
Receiver (as Preamp) - Sony STR-DA3400 ES
Amplifier - Outlaw 7125
Television - 58" Samsung Plasma PN58B860
Blu Ray - OPPO BDP 83 -
Thanks!HiFi Setup: Luxman L-100U and T-110, Pioneer PL-516, Sony DVP-NS57P, Polk LSiM703, Polk DSW Pro 440wi
Home Theater Setup: Onkyo TX-NR709, Polk LSi7, Polk LSiC, AR Sub -
Or another LSi7 if it would work for your set-up.
Found a LSiC on ebay, it was in great shape, had to get it! Now I need to find another pair of LSi7's for the rear surround...HiFi Setup: Luxman L-100U and T-110, Pioneer PL-516, Sony DVP-NS57P, Polk LSiM703, Polk DSW Pro 440wi
Find a pair of LSi 9's for the front and put the 7's in the back if you have the power to drive them.My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Eh the 7s are just fine if you have a good sub.
Plus the 7s are WAY easier to mount.
I'd suggest the LSI f/x as surrounds but they are pricey compared to the 7s.
If your going 7.1 do the 7s as rear surrounds and the f/x as side surrounds."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I like all 7's as surrounds and surround back, hell I think a 7 system with the LSIC is a complete package. Complete Synergy.Dan
Is there really much a difference between the LSiC and the LSi9? Just a larger frame on the LSiC...HiFi Setup: Luxman L-100U and T-110, Pioneer PL-516, Sony DVP-NS57P, Polk LSiM703, Polk DSW Pro 440wi
The LSi9 has a larger internal volume and the drivers aren't spaced as widely the LSiC. When I went from LSi9 to LSiC as a center channel I noticed that there was a wider horizontal dispersion of the center channel dialogue and a decrease in lower end/midbass.
I got the last of the LSi7's I needed to complete the 5.1 setup, Thanks to Ryan!
