Teac A-H01
zingo
zingo Posts: 11,258
I just bought a Teac A-H01 for my wife as I need something that will effectively power 4ohm speakers, yet is small and has a subwoofer out. I found this little integrated amp, and liked the specs, and the internal DAC was just a bonus. Most little amps use a Chines chip amp, or a cut-rate class D modules, but the Teac uses the 50ASX2 by Bang & Olufsen ICEpower of Denmark. She wanted something to provide good music at a good volume, but didn't know whether she wanted me to install it in the kitchen or living room yet, but either way this amp will fit the space and the bill. It has a remote, analog pot for volume, and should be a good fit being fed with a Squeezebox Touch. I only have a few hours on the unit but I already highly recommend it as I'm not sure you're going to find something with better sound and better functionality for a cheaper price.
http://audio.teac.com/product/a-h01/
D/A Converter Burr-Brown PCM5102
USB Input USB2.0 High-Speed
USB Transfer Mode Asynchronous Transfer Mode
Digital audio Input Connector USB-B, RCA Coaxial, Toslink Optical
Analog audio Input RCA
Supported Sampling Rate 32/44.1/48/88.2/96/176.4/192kHz
Supported Bit Rate 16/24bit
Speaker Output
Connector AWG8/BANANA-Plug
Supported Impedance 4 ohms to 8 ohms
Maximum output 60W + 60W (4 ohms, 1kHz, JEITA)
30W + 30W (8 ohms, 1kHz, JEITA)
Frequency Response 10Hz to 80kHz (+/-3dB)
S/N Ratio 100dB (LINE Input、IHF-A/input short)
THD 0.05% (1kHz, 4 ohms)
Headphones Output Connector 1/4"(6.3mm) Stereo
Maximum Output 50mW + 50mW (32 ohms loaded)
  • George Grand
    George Grand Posts: 12,258
    Cute little sucker.
  • voltz
    voltz Posts: 5,384
    I so agree, but that is a nice little amp there. Keep us updated to how you like it.
    tonyb Posts: 33,069
    Be nice if it had some line outs...otherwise looks like a neat little sucker.
  • zingo
    zingo Posts: 11,258
    So far so good. I current have it set-up with a pair of Focal Sib speakers, a Focal Cub subwoofer, and connected to my PC via USB. The Async USB driver was not plug-n-play as I had to download it from the Teac website, but it works great now and provides nice musical reproduction.
    mhardy6647 Posts: 34,960
    edited November 2014
    It's adorabe - and I am not being facetious.
    - As an old guy (and FWIW), the more traditional form factor of this TEAC works better for me aesthetically than the (fairly) new (and highly regarded) NAD D3020.
  • zingo
    zingo Posts: 11,258
    I looked at the NAD as well, but also couldn't get past the form factor, and I liked that the Teac's amplification is a known quanity unlike most mini-amps; ICEpower.
  • pearsall001
    pearsall001 Posts: 5,257
    If it's anything like my TEAC UD-501 DAC then I'll say that you've got a remarkable piece there. Enjoy!!!
  • zingo
    zingo Posts: 11,258
    It's a neat little amp and it obviously has modern elements like an internal DAC and class-D output stage, but is a little old school as the power button is manual, and the volume is a motorized analog pot. I agree a lineout would be nice, but the subwoofer out is still rare at this price and size.
  • coolsax
    coolsax Posts: 1,826
    its a great little amp, I currently have it running my desktop computer system.. powering a couple of 6ohm Jamo speakers. The Head amp on it is pretty good too.. only wish it it had digital out on it incase I wanted to use it as a Dac only in the future.
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
