WYRED 4 SOUND Pre Amp STP-SE Problem..
Toolfan66
Last night I was listening to my stereo, and all was fine, I shut it down as I normally do.
Today I turned it back on to listen to some music, and my remote will not work, I know it's not the remote as it runs my DAC2 just fine but it will do nothing on the Pre Amp.
The pre is running, but I have to manually turn the volume up or down or switch inputs..
No clue to what could have happened but I'm bummed about it..
Larry, try a reset by unplugging the pre amp for a bit. If that doesn't work, something with the sensor circuit has gone bad.Political Correctness'.........defined
President of Club Polk -
I was thinking/hoping the same thing, I unpluged it last night, I will plug it back in when I get off work today. If not I will call W4S tomorrow, at least it's under warranty..
Hope you find a fix soon Larry, between spinning Vinyl and a pre with no remote, you're going to wear yourself out!
I will have to call w4s tomorrow nothing has worked..
The remote just stopped working on my w4s dac 2 so please post back your results.
Both Toolfan66 and polkfarmboy issues sound familiar with the Wyred STP-SE and DAC-2 I had/have, unplug wait a couple minutes and plug it back in and you should be good to go. I vaguely recall there might be a system reset you may also need to perform on the STP-SE if thing get really crazy.
Any word from W4S Larry?"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
I'm waiting for an RMA # to send it in..
W4S now has my Pre, but I haven't heard anything yet..
I will have my PreAmp back on Monday. They sent a email saying they had to change out the IR and a ground wire. They didn't go into any details as to what might have happened..
I'm just glad it's on its way back.. -
Goodness...hopefully she comes back firing on all cylinders!2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A
What'd I tell ya
You hit the nail on the head!!
Glad it's a quick turnaround."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
Nail on the head sounds pretty scary.
I'm glad they took care of it so quicklyAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
Up and running!!! All is good, can't say enough about their CS...
