WYRED 4 SOUND Pre Amp STP-SE Problem..
Last night I was listening to my stereo, and all was fine, I shut it down as I normally do.
Today I turned it back on to listen to some music, and my remote will not work, I know it's not the remote as it runs my DAC2 just fine but it will do nothing on the Pre Amp.
The pre is running, but I have to manually turn the volume up or down or switch inputs..
No clue to what could have happened but I'm bummed about it..
    F1nut Posts: 51,963
    Larry, try a reset by unplugging the pre amp for a bit. If that doesn't work, something with the sensor circuit has gone bad.
    Toolfan66 Posts: 18,165
    I was thinking/hoping the same thing, I unpluged it last night, I will plug it back in when I get off work today. If not I will call W4S tomorrow, at least it's under warranty..
    :smiley:
  • Mike Reeter
    Mike Reeter Posts: 4,315
    Hope you find a fix soon Larry, between spinning Vinyl and a pre with no remote, you're going to wear yourself out!
    I will have to call w4s tomorrow nothing has worked..
  • polkfarmboy
    polkfarmboy Posts: 5,703
    The remote just stopped working on my w4s dac 2 so please post back your results.
  • Polkitup2
    Polkitup2 Posts: 1,642
    Both Toolfan66 and polkfarmboy issues sound familiar with the Wyred STP-SE and DAC-2 I had/have, unplug wait a couple minutes and plug it back in and you should be good to go. I vaguely recall there might be a system reset you may also need to perform on the STP-SE if thing get really crazy.
  • drumminman
    drumminman Posts: 3,396
    Any word from W4S Larry?
    I'm waiting for an RMA # to send it in..
    W4S now has my Pre, but I haven't heard anything yet..
    I will have my PreAmp back on Monday. They sent a email saying they had to change out the IR and a ground wire. They didn't go into any details as to what might have happened..
    I'm just glad it's on its way back..
  • hochpt21
    hochpt21 Posts: 5,423
    Goodness...hopefully she comes back firing on all cylinders!
    F1nut Posts: 51,963
    Toolfan66 wrote: »
    What'd I tell ya B)
    Toolfan66 wrote: »
    What'd I tell ya B)
    You hit the nail on the head!! :smiley:
  • drumminman
    Glad it's a quick turnaround.
  • Mystery
    Mystery Posts: 2,546
    Toolfan66 wrote: »
    Toolfan66 wrote: »
    What'd I tell ya B)
    Nail on the head sounds pretty scary. ;)
  • GlennDog
    GlennDog Posts: 3,158
    I'm glad they took care of it so quickly
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
    Up and running!!! All is good, can't say enough about their CS...
