Used Pre/Pro Recommendations?
I'm looking for a pre/pro or receiver with preouts to drive my SDA's. I won't be using it for music, as I have the Anthem tube pre for that. Any thoughts on what I should be looking for with a budget of $400? I don't really need HDMI, as I have those plugged in the TV, but will need optical/coax inputs. This will be replacing an old HK receiver that finally burned out on me.
ChrisIntegrated Amp: Cary SI-300D Processor: Marantz SR7012 Streaming: Bluesound Node 2I 4K Bluray: Panasonic UB820Mains: Von Schweikert VR2Center: Von Schweikert LCR15 Subs: 2 SVS Sb13 Ultra (HT Only) Analysis Plus Cables
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited November 2014
    This. Refurbished with a one year warranty, with an option to purchase an extended warranty. Otherwise I would you will likely be buying used at that price point.
    http://www.accessories4less.com/make-a-store/item/yamrxa810bl/yamaha-rx-a810-home-theater-receiver-networking-3d-ready-hdmi/1.html
  • dagame27
    dagame27 Posts: 599
    Any thoughts on going with something like an Anthem AVM2 or B&K reference 30 or 50? I don't need video switching at all.
    EndersShadow Posts: 17,687
    dagame27 wrote: »
    If you just need optical and coaxial switching ONLY whats about this?
    http://forum.polkaudio.com/discussion/164621/audio-authority-digital-switch#latest
    Otherwise a B&K Reference will work just fine, though your gonna pay a premium for that brand and anthem as well.
    tonyb Posts: 33,065
    A premium ? Your smoking dope Dan. B&k pre/pro's go all day for 3-500. Also check out some Proceed AVP's....lots going for them with a Mark Levinson pedigree for under4 bones.
    Curious though, you don't need bluray decoding ? DTSHD Master audio ? Or does your BDP have analog outs ?
  • dagame27
    dagame27 Posts: 599
    I'm only running 2 channel with a ps3 as a bluray player. It can do 2 channel lossless through optical. I do have an HDDVD player that i wouldn't get the latest and greatest sound out of, but I guess I don't use it that much to begin with.
    tonyb wrote: »
    LOL, c'mon Tony thats not legal here in Indiana..... Now if I was up in CO like Larry, or seattle like Zingo..... :smiling_imp:
    Let me rephrase, for 3-500 you can get a refurb AVR that can do that as well and has video switching so you have it as a backup if your main unit (assuming you have a HT setup) goes out.....
    I was attempting (and failing) to convey that the B&K processor (which do video, albeit outdates) are a bit high IMHO given their legacy audio formats.
    Heck Rich sold his Marantz 7002 for all of 200 bucks and its a bit BETTER than the B&K stuff....
    tonyb Posts: 33,065
    Personally I liked the B&k processors better, but either way....200 bucks-400 bucks....that's considered a premium ? We spend that on IC's.
    BTW...to the OP, pre/pro's won't drive anything as they have no amp section. Maybe clarify exactly what it is you prefer. 400 bucks though isn't going to get you much in an AVR, but will grant you some options on higher end pre/pro's minus the HDMI and current decoding.
    Your missing out on DTS hd master audio with your hook ups. Yes, it's worth it.
    For your budget though, B&K Ref 50.
    ...or, http://chicago.craigslist.org/wcl/ele/4742722490.html
    ...but I think the B&K has better dacs in it.
  • dagame27
    dagame27 Posts: 599
    I have an adcom 555 ii driving sda SRS 2s, with an anthem pre 2l as a music pre. I used to have a polk monitor 5.0 rig with an entry level elite receiver, but just two channel nowadays. I was using a Harman kardon avr 235 as a processor, but it went out on me
  • Irrenhaus
    Irrenhaus Posts: 1,098
    You mention not for Music. How about an Emotiva XDA-2 is DAC/Preamp or a used XDA-1
    or a Stealth DC-1. Now no affiliation with Emotiva...:')
    My 2cents
    Cheers
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • dagame27
    dagame27 Posts: 599
    Would the DAC in the Emotiva sound as good as one in an older B&K? This will be mainly for HT.
    tonyb Posts: 33,065
    dagame27 wrote: »
    Ok, color me confused. If your just 2 channel these days, why do you even need a processor ....or a receiver ?
    Can't you make some adjustments in the PS3....plug it into your Anthem ? Otherwise, if your going to keep the anthem for 2 channel, go with a used pioneer elite 21 or 23....which can be had for 2-300 bucks. That will give you hdmi, current decoding, and be able to re-route signals from missing speakers.
  • dagame27
    dagame27 Posts: 599
    The anthem tube pre only has analog inputs and my cable box only has digital output. The Anthem also has an HT bypass, which is how I had it hooked up to the Harman Kardon, until it went out earlier this week.
    tonyb Posts: 33,065
    Gotcha bro....then the used Pioneer receiver should work, or a processor as I've suggested but the receiver will give you additional amped channels in case you ever want to add more speakers.
  • I've lost track of the OP question but how about a
    Gefen GTV-HDMI-2-HDMIAUD?
  • dagame27
    dagame27 Posts: 599
    Would an Integra 9.8 be worthwhile? I've seen some right at the upper edge of my budget.
    tonyb Posts: 33,065
    I don't see why not....it's a solid unit and has everything. The only thing missing is the ability to do 4k if that's any interest to you.
  • dagame27
    dagame27 Posts: 599
    Thanks Tony; I'll probably have my TV do the video switching anyway. I appreciate everyone's help. I guess it's a good thing to have so many choices!
  • DaveHo
    DaveHo Posts: 3,582
    dagame27, sent you a PM about an Onkyo PR-SC885
  • dagame27
    dagame27 Posts: 599
    Pm responded to!
