Bi-Amp or not?
dkoutnik
I recently purchased a pair of the LSIM 705 towers, im currently running a Denon AVR-2312 receiver that has discreet amplifiers (7) total, I did also do my system the justice of buying solid core power cables, and a power conditioner. Currently I'm using Audioquest g2 speaker wire that i had terminated with banana plugs, but will soon be upgrading to some better stuff. So, now to the question should i Bi-Amp these speakers or just keep it jumped until i get a better amp, thoughts and suggestions would be helpful! Thanks!
Post edited by dkoutnik on
Ok, here we go again. You cannot bi-amp with an AVR, so forget about it. Replace the stock jumpers with high quality speaker cable, sit back and enjoy.Political Correctness'.........defined
President of Club Polk -
Polly want a cracker ? lol !!HT SYSTEM-
lsi 9's -
http://www.denon.co.uk/uk/Product/Pages/Product-Detail.aspx?Catid=HomeTheatre&SubId=AVReceivers&ProductId=AVR2312
Your 100% sure on that? Denon's website says different.. -
OK, first, I will address the "discreet amplifier" portion.
The 2312 has individual amplifier sections (boards if you will). But that's as far as the "discreet power" goes. You will notice that it simply says "discreet power" and not "discreet power supplies"? That is because they share the same power supply. This makes it technically impossible to bi-amp using an AVR. As loads increase (adding speakers), the power being sent to each channel decreases. The AVR-2312's power ratings are with 2 channels driven at 6 and 4 ohms. Your speakers are an 8 ohm speaker which means that the amount of power is even further reduced.
Ultimately, you are looking at the neighborhood of 80-90wpc at 8 ohms with all channels being driven...most likely less.
Now let's address what true active bi-amping is.
You will need seperate high pass and low pass amplifiers, an active crossover network and to remove the passive crossover from the equation.
Simply connecting both sets of binding posts to seperate amplifiers only accomplishes half of this. The crossover inside the cabinet is still part of the equation.
Here is the concept in illustration form:
"Do I need to disconnect the passive crossover in my speakers?"
The answer is ... Yes, otherwise you are not really biamping at all.
Passive biamping (where two amplifiers are used in a bi-wiring connection) is, IMHO, a waste of money. Although there may be some moderate sonic benefits, they are not worth the expense of the extra amplifier. (And to promperly actively or passively bi-amp, you *will* need seperate amps)
So, with that said, what would you suggest for an amplifier? Ive got access to just about anything i need through work, currently the speakers are in a home theater system i had (klipsch) but ive been mainly listening to music lately with very little TV viewing.. I'm using a Peach Tree DAC hooked up to my system currently and its helped calm down the harsh music so far, but i need more power to the speakers clearly to make them sound like they should. -
You may not like the sound that Klipsch offers, many don't like the horn drivers. Denon generally produces a warmer sound.
In most cases Klipsch are one of the easier speaker lines to drive, IMHO you have a speaker your not happy with and an amp may not resolve the issue.2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
txcoastal1 wrote: »You may not like the sound that Klipsch offers, many don't like the horn drivers. Denon generally produces a warmer sound.
Let me try this again lol, i worded it completely wrong, I replaced my RF82's with the Polk LSIM705 speakers, and im looking to get some better sound out of the polks, im running a pro660 sub with the set-up currently and am running it as a 2.1 system b/c i dont want to drowned out the polk's with the horn tweeters.. -
Without a doubt.So, with that said, what would you suggest for an amplifier? Ive got access to just about anything i need through work
Ok, what do you have access to and how much do you want to spend?Political Correctness'.........defined
Sorry my bad got caught up in post#6.
Surprised you are having harshness from the 705's, as I have listened to the whole LSiM line several times and actually the 705's are my favorite.
refer to what F1 asked
Welcome to CP2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
I have access to Integra, Macintosh, Rotel, sony, and a few others, ive worked in the business for 2 years, but ive never dealt with "Higher End" just the simple denon, yamaha, HK, etc.. pricing isnt much of an issue, but i dont want to spend 20k or 10k on a macintosh system. looking to spend no more then 2500.00
txcoastal1 wrote: »Sorry my bad got caught up in post#6.
Welcome to CP
As far as harshness, the speakers are great with most of my music, but i also use some streaming services and thats typically where i have the DAC coming into play.. -
Ok, not on your list, but I'm going to recommend it anyway. Bel Canto and LSi M's go very well together. Add some MIT cables and you're in for a real treat.Political Correctness'.........defined
" as loads increase(by adding more speakers) power( delivered) decreases"
"you cannot bi-amp with an AVR"
Both false. The spec for my Denon AVR X 1100-W reads:80 watts continuous rms per channel with all channels driven into 8 ohms from 20-20,000 khz. with 0.05 thd.
You absolutely CAN bi- amp with an AVR. I bi amped my Rti a5 speakers using the front right and left and the surround back right and left amp outputs, just like the owners manual says, and the speakers sound awesome. Audibly better than with one amp driving each speaker. The amps actually deliver MORE power in this hookup because the individual drivers present a simpler lower load impedance. -
You can bi-wire and bypass any jumpers altogether.
Wrong, wrong, wrong.
At 18lbs. your AVR doesn't have a power supply capable of delivering 80wpc to 5 never mind 7 channels. H e l l, my CD/SACD players weigh more than that. Anyway, study the post by ZLTFUL above to see what bi-amping really is.
Any improvement you are hearing is because you have removed the c r a p p y stock jumpers and would get the same result by simply replacing the jumpers with high quality cable.Political Correctness'.........defined
F1.....you can talk about this till you are blue in the face...yet some people never learn....like talking to a wall....Bel Canto is excellent gear...never heard it mentioned here before...Buddy owns some..swears by it...and I'm a believer...my next buys will be this line....very good match with LSim as you said...
He means " Bi wire"Emotiva XPA5, Sony ES 5300,: Lsi 15,s LSIC, Monitor 70,s, ( side surrounds) FXI 3,s, (rear surrounds)Micropro4000, Velodyne DEQ 10, Sony 55inchXBR 930D Sony BDP 790 Bedroom rig SonyES 3200 RTIA1,s CSIA4 FXI3,s polk PSW 10 SONY 34inch XBR960:cool:SONY BDP550
Hello,
Yes you can bi-amp with an AVR but why? I have a Sony STR-DA5700ES AVR pushing RTi8's tried to bi-amp, did it sound any better? No! A friend was trying to sell me some RTi12 and said if I bi-amp my receiver could push them. I still have my RTi8's. The 5700ES is a very good 40lb AVR
Funny F1nut said to remove the jumpers. when I took the bi-amp off I flattened the jumpers a bit and used silver audio solder (so I would try to bi-amp again). Sounds much better now.
If you want to make the LSIM 705 sing you will need an amp. Emotiva XPA to start.When I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
Working Warehouse; Yamaha A-S301, Sony DVP-NS3100ES for disc Plok TSX550T SVS PB2000 Mini tower PC with 400GB of music -
NO, you cannot bi-amp with an AVR, period.when I took the bi-amp off I flattened the jumpers a bit and used silver audio solder (so I would try to bi-amp again).
Sorry, I'm not understanding what you did there.If you want to make the LSIM 705 sing you will need an amp.
Agreed.Emotiva XPA to start.
That would be a poor start.
RTI use a gold looking steel plate for a jumper. I noticed they were not making the best contact. So I used a little solder and a hammer to make them have the best contact.
Emotiva is not the best but its better than trying to dive them speakers with an AVR. If they have the money then a parasound halo would do the trickWhen I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
Got it, thanks. Even better, dump the plates and replace with high quailty speaker cable.
Solder and a hammer ?? What ??HT SYSTEM-
lsi 9's -
Polk uses a piece of steel as a jumper on the RTi line. When I tried out bi-amp my RTi8 and my friends RTi12 I noticed the plate are not machined very well. They had a cup affect in the area around the post. I would take a picture but to ensure they are tight I solder them in. After a little engineering (hammered flat) they are now making perfect contact.When I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
http://s005.osstatic.net/s/polk/store/productimages/details/1055_cherry_c.jpg
that's the steel plate going from the bottom post to the top. It's not machined very wellWhen I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
You had me worried for a second that you soldered your binding post together or something LOL. now I see what you meant. but I would recommend getting rid of them completely and going with some jumpers instead as others have said.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Who resurrected this old thread!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
The binding post jumper plates are not made of steel, they are gold plated nickel. Many RCA connectors use the same combination of materials.
sorry I did. I lurk around this blog for the past 8 years. I see people who want to bi-amp with an avr and have to toss in my two centsWhen I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
Per my post in the bi-wiring thread, I tried this yesterday, I think. Or is Yamaha fooling me in their instructions for my RX-V675? It is a fairly simple setting in the set-up menu.
When you bi-amp....you remove the those brass plated jumpers, not solder them in place. Just sayin'.HT SYSTEM-
lsi 9's -
I believe that what mrloren, F1nut and voltz are saying is that the jumpers supplied with the speakers does not give a really good connection so it should be replaced with something that will connect at least as good as your speaker wire connects to the first posts. Thinking about it, putting in a jumper made from the same speaker cable that connects your amp to your speakers makes a whole lot of sense - I'm going to do just that today!
That's gotta be 'way better'n bi-wiring with inferior speaker wire like I spent too much time doing yesterday!!
LOL!!
