connect 2 sub question
jojomgee
Can you connect 1 sub with speaker wire and connect the other sub with the rca to receiver input? Will that screw up crossover? Will it work at all?
http://www.amazon.com/AudioQuest-splitter-female-15-24cm-cable/dp/B000GUSQJG
Just get you one of these and a extra rca cable for your 2nd sub, done deal!Home Theater
Thnx, I know about the splitter.... but im antsy & wanted to test 2 subs tonight....lol...
The problem with what you're suggesting, is the crossover for the LFE/Subwoofer out on your receiver is set by the receiver. Using the speaker level connections on the other sub may or may not work, because the bass is rolled off already, so that sub might not be getting any low frequencies at all. Set the front speakers to "Large". This should provide full frequencies to the front left and right, and low frequency signal to the LFE/Sub out on the receiver.Home Theater/2 Channel:
dhsspeakerservice.com/
