"Homemade" coax cable
Made a quad coax RG6 cable to go from the Oppo
to the Emo XDA-2. Should I break it in playing my
favorite song over and over or put my fav CD on repeat?
  • OleBoot
    OleBoot Posts: 3,135
    edited October 2014
    favorite song over and over or put ymy fav CD on repeat?
    Raise it 5.374" off the floor on soapstone supports that have been rubbed between the knees of a Dali Lama, stare at it a lot and try to project positive energy. Alternatively, just have a glass of something and play some tunes.
    Edit: Oohh, my 100th post, I will wear my badge with glee.
  • I think I'll do the latter! :)
    Well, I was hoping for an improvement... :\
    tonyb Posts: 33,069
    That's usually the response with homemade cables....unless your starting point is coat hangers.
  • Ain't that the truth. The thread was supposed to be
    a kind of joke. As I had not even started one on the
    new site... this is all I could come up with. :p
  • I did make the cable and failed however :)
    SCompRacer Posts: 9,092
    I've used single ended coax RCA's for years. Stranded center core is the way to go for flexibility.
  • "Make yourself necessary to someone. Ralph Waldo Emerson"
    I try to act on this every day since reading your siggy.
    Someone mystery? comment on this great coax cable to get
    which is no long manufactured... so I took a stab at my own
    as it had BNC ends. I'll search the site for suggestions...
    edited October 2014
    Necessary isn't so bad. There are alternatives of course. ;)
    You can google rca coax connectors, RG59 rca coax connectors, etc. Different designs (crimp, solder, compression) and quality available.
    I was sourcing these from Parts Express but I see they are no longer available there. I liked them cause they were threaded compression. Center wire is soldered to pin.
    http://www.parts-express.com/gold-rca-plug-connector-for-rg-59-coax-pair--091-400
    Sanders Sound sold me some RCA coax connectors that were similar to above but were of better quality. He uses them on his cables and may still sell them separate.
    You can use standard RCA connectors which requires unbraiding the braided wire and twisting it into a wire end. If you cut the braid you get splinters of wire. I use a pointy tool to unbraid it. Main thing is don't cross the streams, in other words don't short to center conductor.
  • Good lead thanks! Using the search tool and reading around it seems this is a interconnect project to nowhere. :#
    edited October 2014
    These coax RCA's came off an old Linn LP12 turntable IC. I could never find any like it. The braid is split into two leads. Good luck in your quest!
    Duh, I forgot about Vampire terminations. I installed an entry level pair of RCA's on a friends turntable, my old Yamaha YP-D10. (Got rid of them cheap plastic ones). I did have to drill out the ends slightly for the large diameter coax Yamaha used.
    These are like the ones I am using. $22.50 a pair.
    Vampire coax RCA products page.
    http://www.vampirewire.com/viewcategory.php?groupid=0
    Post edited by SCompRacer on
  • tophatjohnny
    tophatjohnny Posts: 4,188
    Consult with Doug @douglasconnection.com He is the most knowledgeable person I have ever talked to about cables, makes a killer product, and a great guy as well. He is also a member here.
  • Wow! nice Vampires (and timely). Looks to be exactly what I'm looking for.
    And I'll check out the DC.com. Thanks!
  • My thank you post disappeared some how.
    So thanks again for the leads!! :)
