My 1'st RDO 198 experience
boston1450
Well I'm not extremely picky when it comes to tweeters. I was so wrong. I have enjoyed my Polk adventure so far. I've listened/owned many & many of Polk speakers. Really enjoy the Peerless tweets. Well I decided when I got the RTA15tl's I was going to upgrade the tweets asap. Thanks for the push Sea
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
by David WMG
Randy-Maine
by David WMG
Randy-Maine
by David WMG
Took left side out & listened to it for 2 mins. Big difference. Put other side in & put on a Dream Theater cd & was blown away. Well worth the $$$. I recommend these RDO's to anyone who thinks the sl's are great. They are but these are far more betterer
Randy-Maine
by David WMG
I found the same thing, smoother yet crisper with better transients c/w the SL3000's."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
Hard to beat a silk dome tweeter for smoothness and musicality.Home Theater/2 Channel:
dhsspeakerservice.com/ -
It's not a big deal, but the actual Polk part number is RD-0198.
I have them in my Monitor 10's now and I love them. Since Dave did a TL upgrade of my crossovers I was able to upgrade to them! I have heard things or at least in a way I never did before!
Rock On Randy!!2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Thanks. After hearing these - Now I'm wanting to change out the CRS's. Do the 0194's VS sl2000 sound that much different too. I'd love to upgrade completely. But wallet says no & winter is coming $$$ up hereRandy-Maine
by David WMG
Which generation CRS+s do you have?boston1450 wrote: »Thanks. After hearing these - Now I'm wanting to change out the CRS's. Do the 0194's VS sl2000 sound that much different too. I'd love to upgrade completely. But wallet says no & winter is coming $$$ up here
Not sure?? Will post picturesRandy-Maine
by David WMG
Randy-Maine
by David WMG
Those appear to be 4th generation, and can be "TL" modified, to use the RDO-198-1s. The RDO-194-1s are drop-ins. The interconnect should be pin/blade.Home Theater/2 Channel:
With a few parts and a little work you could convert your M10s to SDAs. Well worth it. You would be surprised how great your 10s can sound.I have them in my Monitor 10's now and I love them. Since Dave did a TL upgrade of my crossovers I was able to upgrade to them! I have heard things or at least in a way I never did before!
Rock On Randy!!
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
Yes they are. Thanks for the info on series. I will say this. They have the bass to back up their size for sure. Seem to me if they are set about the same position as bigger SDA's let's say 6ft apart. To me they seem to fill the room very wellRandy-Maine
by David WMG
If you upgrade the sub-base drive inductor, the bass will be stronger and deeperboston1450 wrote: »Yes they are. Thanks for the info on series. I will say this. They have the bass to back up their size for sure. Seem to me if they are set about the same position as bigger SDA's let's say 6ft apart. To me they seem to fill the room very well
Good to know. I may try pulling them away from back wall a tad bit & play around with that till I get the right spot.... I'm using 2 stands per speaker & it seems to be working out ok for now. The CRS's are hooked to the Marantz & it seems to me to be working ok. I'm sure I could make them sing with more power. But for normal listening on vinyl they seem to be working quite well.Randy-Maine
by David WMG
I just pulled them out 3 inches. I will see if that helps. I have the bass down on the receiver to 2nd notch. Any higher it's overwhelmingRandy-Maine
by David WMG
Must be room interaction, combined with weak caps. The CRS+ are well balanced, and have plenty of bass, but the quality improves dramatically with crossover rebuild, and new sub-bass inductors.boston1450 wrote: »I just pulled them out 3 inches. I will see if that helps. I have the bass down on the receiver to 2nd notch. Any higher it's overwhelming
Pulled them out earlier & it made a difference. Room is terrible. They are a little too close together at around 3.5 feet. We are re-doing upstairs & it has drained us $$$ wise. Little at a time. The upgrades will be happening eventually. I'm right where I want to be as far as buying gear. Matter of fact I've downsized quite a bit lately on gear. Did some upgrades on CD player & tweets that were gonna happen anyways
The RT-909 goes on bottom & should be home this week-3 month rehabRandy-Maine
by David WMG
Very nice, but a bit too close as you say.Home Theater/2 Channel:
Yes. There is a door that opens on the left side & as you can see the right side is 12in from wall. This is only temporary. Wife isn't happy they are in dining room & I'm not putting gear in cold barn/garage temporarily. Very happy with the CRS's. Even more so than the 7'sRandy-Maine
by David WMG
Rock On Randy!!
Tenn Man do tell...I am def interested.Cool stuff: Adcom GFA-555, GFP-710, Oppo BDP-83, Monitor 10's w/RDO198s, rebuilt and modded XO: Sonicap/Mundorf topside, Daytons Low.
Benq W5000
"Leaning back like a maxwell tape commercial listening to pure polk bliss" -
Rock On Randy!!
you got my interest Ronnie! but I think my 10 kick serious buii right now
you got me very curious thats for sure
There is an entire thread I started 2-3 years ago that discusses me putting SDA crossovers from CRS+ speakers in monitor 10 cabinets. Some people said I was making a mistake but it turned out really well. The good part is you don't have to modify any wires or butcher the cabinets. It is easy to put the monitor 10s back to stock configuration anytime you want. With this new and improved forum I'm not able to find that thread. I preferred the sound of the SDA 10s over my CRS+ that I still have. More bass with the front firing passive radiators in my opinion. I put the monitor 10s back to stock and sold them when I got my 2Bs. I don't have the room for a lot of extra speakers.
boston1450 wrote: »Thanks for the push Sea
I think Sean Connery (as Bond, James Bond) said that in every 007 movie he was in!
Cool im gonna try a search....would you say they imaged better? your 2b's are same as the crs+ or they are 2 different sets? trying to learn more about sda...while the other side of my brain panics about monitor 10 seperation anxiety...rightfully so I says.Cool stuff: Adcom GFA-555, GFP-710, Oppo BDP-83, Monitor 10's w/RDO198s, rebuilt and modded XO: Sonicap/Mundorf topside, Daytons Low.
Benq W5000
I don't think they imaged better than the CRS+. CRS+ shine in the imagine department. They were on par with the 2Bs in that respect. As well as getting the SDA effect when you modify the 10s, I feel you get deeper and more defined bass compared to the CRS+ or the stock 10Bs. The bass of the 10s has more punch in IMHO. I wish I still had my 10s so I could try my 2BTL modded parts on them. My 2Bs have Sonicaps in the crossovers, Erse inductors and RDO-198 tweeters. All will work in the monitor 10 cabinets.
I have a set of CRS+ speakers that are in storage in the closet and I have a pair of 2Bs with the TL upgrade that I listen to all the time. The 2Bs are a much larger speaker than the CRS+. For comparison I have posted a my 2Bs in my living room and my CRS+ before I packed them away.your 2b's are same as the crs+ or they are 2 different sets?
boston1450 wrote: »
I have the same rack but really afraid to put anything heavy on those thin glass shelves.
Looks like they hold fine...
^^^^ i hear you there. The items you see are light & it did in a pinch & it was a 10.00 rack
Randy-Maine
by David WMG
boston1450 wrote: »^^^^ i hear you there. The items you see are light & it did in a pinch & it was a 10.00 rack
I overpaid then at $21.
