LSi25 Crossover problem??
Hi, I have a pair of LSi25´s. One of them needs a new tweeter and the other speaker that has a good tweeter shuts off the tweeter at about half volume and resets it. I believe I need a rebuilt crossover in that speaker? Can anyone please help. Thank you.
  • Hello,
    Replacement crossovers should be available from Polk's CS department, you can telephone them at 1-800-377-7655 or use email polkcs@polkaudio.com
    Mention you are a Club Polk member for cost savings.
    Regards, Ken
  • Thank you so much my friend! I will be calling them tomorrow. As I meant to state earlier, I purchased these as demo speakers. They came to me in this condition.
    Thanks again!!!
    edited February 2015
    Thanks again!!!
    What the guys are trying to get at is....how do you know you need new crossovers ? Did you look at them and see if anything was burnt on the board ? Maybe all you need is a resistor....maybe all you need is a tweeter.....maybe a wire came loose. Do you have them hooked up properly ? Hate to see you buy new crossovers and they still don't work.
    That said, they came to you as demo's from an Audio store ? I would never buy a thing from them again.
