Removing grille on in-ceiling speakers
bbriedis
bbriedis Posts: 9
edited March 2002 in Technical/Setup
I just ordered and received two pair of Polk RC80i in-ceiling speakers. I am having a real difficult time removing the grille. The instructions say to use a paperclip or corkscrew, but a small paperclip is not nearly strong enough to loosen the grille at all. A large paperclip will not even fit through the holes in the grille. I tried a corkscrew, but it started to bend the grille without loosening it. The instructions say not to use a screwdriver or other object near the speaker ring as this would cause damage.
Polk advertises their in-ceiling or in-wall speakers as "Out of the box and into the wall, that's how easy it is to install Polk RCi Series In-Wall Loundspeakers." I can't even get to first base. Anyone know what the secret is? Thanks.
BTW - I did try with both speakers. They are both real tight.
Bob
Post edited by bbriedis on
  • ntculenuff
    ntculenuff Posts: 1,146
    edited March 2002
    i would call polk customer service..thats about as much help as i can offer..sorry:rolleyes:
    Speakers:
    Definitive BP7001sc mains
    Definitive C/L/R 3000 center
    Polk RT800i's rears
    Definitive supercube I Sub
    Audio:
    Onkyo TX-NR3010
    Emotiva XPA five Gen 3
    OPPO BDP-103 CD, SACD, DVD-A
    Video:
    Panasonic TC-P65ZT60
    OPPO BDP-103 Bluray
    Directv x's 2
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited March 2002
    Hello Bob,
    Thanks for posting on the Forum. If you'll telephone me at 1-800-377-7655 extension 891 I can send you a small tool which will make life easier for you.
    Regards, Ken Swauger
  • shack
    shack Posts: 11,154
    edited March 2002
    Is this great customer service or what? Way to go Ken and Polk!
  • mantis
    mantis Posts: 17,057
    edited March 2002
    AHHH THE STUCK GRILLE OUT OF THE BOX INWALL SPEAKER,
    wait for the tool that Polk is sending you I have one it looks like a dentist tool you knoe the one he pick's your teeth with??.THEN YOU WONT DAMAGE THE GRILL,They are a pain to straighten back up.
    Dan
    You could use a vewry small screw driver,they work just be carefull you don't scratch up the paint.
    Dan
  • billviverette
    Help! 17 years later and I have the exact same problem. Does anybody have the proper contact info now?
