Next SDA Upgrade
Mikey081057
Putting new walnut laminate on the tops..Bottoms are fine. Has anyone find the stain and finish combination that matches the original stain color? I want to use tung oil as the finish as I like the texture... but would a stain be required to get a close match?
Got the materials for about a hundy, and it appears to be enough to do 4 speaker tops...
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Post edited by Mikey081057 on
After putting the band on, and roughing the top on.
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
I trimmed the top with the trimmer tool.
Cheap simple tool makes it easy
Minimal sanding to do and this one will be ready for finish.My New Year's resolution is 3840 × 2160
Looks nice. Good luck with your project.2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer.
Shweet.
Nice!
Mikey
Could you please tell us exactly what all you ordered (links) and used to do this project?
Do they ship quickly?POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
You'll never get a color match unless you bleach the new walnut first and even then you won't find an exact match in a can of stain. I suggest you reveneer the bottoms as well.Political Correctness'.........defined
President of Club Polk -
Lookin' good Mikey, I would think the project would be a little easier if you removed the tops from the cabinets though.
Take a piece of scrap and hit with the Tung oil, and see what you get. The Tung oil has a warm, gold finish to it, so you might get lucky. Otherwise, as stated above, do the bottoms as well. You've got enough to do 4, right? Good luck, looks good so far.
Ordered all products from Band-it prods. http://band-itproducts.com/
walnut veneer sheet 24x96 and edge banding 2"
it Irons on and really sticks nice ... no bubbles.
I applied it with a teflon iron, and a cheap plastic spackling spatula.
it really takes about 10-15 minutes per top. I thought about removing the top, but then had nothing to hold it in place... so i did it in place, and it worked out fine.My New Year's resolution is 3840 × 2160
I'll have to do this someday on some 3.1s and I have no experience with veneering. What exact type did you get, the pre-glued or the PSA? I have no idea what type works with the iron method you used.Speakers
Polk 5jr+
Polk SDA 2B
Polk SDS 3.1TL
Equipment
Yamaha RX-V3800 Receiver
Analog Sources: Sony TC-K890ES Cassette, Nakamichi DR-1 Cassette, Technics SL-7 Turntable -
GospelTruth wrote: »I'll have to do this someday on some 3.1s and I have no experience with veneering. What exact type did you get, the pre-glued or the PSA? I have no idea what type works with the iron method you used.
Preglued...My New Year's resolution is 3840 × 2160
Mikey081057 wrote: »Preglued...
Perfect. Thanks! Don't know when I'll get to this, but I've saved off that link you posted so that I'll know what to get when the time comes. By the way, your end caps look nice... and they aren't even finished yet.Speakers
Polk 5jr+
Polk SDA 2B
Polk SDS 3.1TL
Equipment
After 2 coats sanded in between. ! more coat will do it.
That looks very nice! I like the walnut way better than the oak. Thanks for posting this. It will help when I get to the point of doing this myself in the next year or so.Speakers
Polk 5jr+
Polk SDA 2B
Polk SDS 3.1TL
Equipment
Did you reveneer the bottom caps as well?Political Correctness'.........defined
If you say so......LOLPolitical Correctness'.........defined
So the next phase of my SDA upgrades is underway.
Drivers have been dampened with Dynamat Extreme.
Cabinets have dampened with Sonic barrier.
Larry's Rings installed.
Replaced crumbling driver gaskets with Armaflex.
Woodwork is being finished on tops and bottoms.
Grills and side fabric have been cleaned with upholstery extractor (they look like new. The amount of dirt pulled out of them was disgusting/amazing).
Trey (VR3) is making new crossovers with full Gimpod/Inductors/Binding plate/interconnect mods.
I am confident that all these improvements albeit expensive and time consuming will result a very high ROI.
BTW I have leftover Dynamat Extreme for anyone who anyone who is in need... PM me if you need some for your vintage polk project.
Post edited by Mikey081057 onMy New Year's resolution is 3840 × 2160
Mikey, looks like your taking the high road on the mods, fun process but hard on the bank account! N'joy
Mike Reeter wrote: »Mikey, looks like your taking the high road on the mods, fun process but hard on the bank account! N'joy
I think when all is said and done I will have a pair of speakers that sound better than what I have invested in them. I don't think I would ever sell them as they represent a nostalgic time for me ( the 80's). I think they will be good(great) for another 30 years!!! I think I will look to stockpile a couple of extra drivers for future replacement if needed as i am sure they will become rare.
Mikey081057 wrote: »Mike Reeter wrote: »Mikey, looks like your taking the high road on the mods, fun process but hard on the bank account! N'joy
You are absolutely right in your assumptions, I'm quite happy with my ole SDA's!
I was surprised when I ordered one of the Do-nut drivers for a former pair of 2.3's, Polk has a good number of them in stock (new replacement) that looked VERY close to the original driver, more so than the new replacement MWxxxx drivers.
I already replace the the sl2000's with RDo-194's
So if i am correct, there are 6513's (donuts) 6510's and 6511's in the 2.3's and Polk CS has replacements you say for all of these?My New Year's resolution is 3840 × 2160
Mikey081057 wrote: »I already replace the the sl2000's with RDo-194's
For sure on the 6513's, this is unless, someone has bought a 150+ in the past few months!
When I ordered they had over 150 in stock.
Mike Reeter wrote: »Mikey081057 wrote: »I already replace the the sl2000's with RDo-194's
I take this back, when I purchased one in Jan. '14 they had 84 in stock, so my guess is they would still have some in stock....wouldn't cost much to give CS a call!
looks nice...good job..Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's
OK so far to date...
Replace SL2000's with RD0-194's Check
Dynamat xtreme driver baskets Check
Sonic Barrier cab interiors Check
Larrys Rings Check
Final finish on tops & bottoms Check
Cleaned Grills and Side Panels Check
Replaced Driver gaskets Check
Deoxit speaker terminals Check
Re assembled with old xovers and terminal cups...for now anxiously awaiting VR3 crossovers, inductors, plates, interconnect and wiring harnesses... (final phase)...
My observations so far... They look nice... sound great can't wait to crank'em tomorrow...bass is warmer and tighter by far... sound is more balanced even at low volume...
Looking good, Mikey! Hopefully, with the crossover mods, you'll be in SDA heaven.
MarkSDA SRS, SDA SRS1.2TL, SDA-1C,SDA 2B, Soundcraftsmen Amplification (A5002s, MA5002s, MA5002As) -
How much Sonic Barrier did you use on the cabinets interior and where???"Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life."
