For Sale REL Acoustics Q201E Subwoofers (2)
KLapinas
KLapinas Posts: 608
edited July 2014 in For Sale (FS) Classifieds
I have a pair of REL Acoustics Q201E Subwoofers available for $1200/pair
One is like new with box, packaging, manual...
One has a few marks but only noticeable if you are looking closely
Both sound amazing
You can review the manual here: http://www.sumikoaudio.net/ContentsFiles/Q-Series-Manual(0).pdf
SPECIFICATIONS:
SYSTEM TYPE: Active ZeroQ Acoustic Suspension System with ABC® variable bass filter. Closed box, 17 litre.
IN ROOM LOWER FREQUENCY RESPONSE AT -6dB: 17Hz
AMPLIFIER INPUT IMPEDANCE: High level 100K, Low level 10K
GAIN CONTROL RANGE: 56dB
DRIVE UNIT IMPEDANCE: 4 Ohm
MAINS INPUT VOLTAGE: 115V 50/60 Hz or 230 V 50/60 Hz, subject to country
DIMENSIONS: WxHxD mm (inches) incl. feet and rear panel controls 300x328x353 (11.81x 12.91x13.90)
WEIGHT: Kg (lbs) 17(37.48)
FINISHES: Bnttex Black, Maple, Cherry, Rosenut, Walnut
FEATURES:
•True 200W (continuous] discrete direct-coupled MOSFET amplifier
•Forward-firing 250mm (10"), long-throw, heavy-duty driver with 7.6 kg magnet and 4 layer edge-wound voice-coil
•Refined ABC® infinitely variable crossover adjustment from 26 to 106 Hz
•Four position mode selector: line/LFE (0 degrees phase and 180 degrees phase)
•Audiophile grade toroidal transformer
•Gas-tight Neutrik high level connection for long-term consistency of sound quality
•High quality, panel-mounted twin phono inputs at 0dB and +12dB (low level)
•Totally discrete input circuitry for high and low level inputs
•Separate volume controls for high and low-level input adjustment
•Simultaneous connection of high and low level sources
•Set-Safe® audibly transparent driver protection
•4x ultra-rugged output devices
•Double-sided glass-fibre board with plated-through holes
•IEC power input socket - non-captive lead for installation flexibility
•Heavy duty grille
•Hand-built in Great Britain
•Three year worldwide warranty
Post edited by KLapinas on
  • Dawgfish
    Dawgfish Posts: 2,554
    edited June 2014
    REL makes the most musical sub's out there imho. If you are looking for a quality pair of sub's, especially in a two channel setup, these are hard to beat. GLWTS!
  • KLapinas
    KLapinas Posts: 608
    edited June 2014
    Thanks for the support Dawgfish. They fill in the bottom octave quite nicely. They were a nice match to the Legacy Audio Classics I just sold.
    Dawgfish wrote: »
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited June 2014
    Dawgfish wrote: »
    I've heard this same thing time and again about REL subwoofers, a solid sender of a musical sub, fantastic craftsmanship and integrity built through and through. GLWTS!
  • KLapinas
    KLapinas Posts: 608
    edited June 2014
    Polkie2009 wrote: »
    Thanks Polkie2009! Very musical subs that do a great job with movies as well!
  • KLapinas
    KLapinas Posts: 608
    edited June 2014
  • KLapinas
    KLapinas Posts: 608
    edited June 2014
    Wow, not interest or offers on these! $1100 for the pair
  • classic carl
    classic carl Posts: 662
    edited June 2014
    Where in Central PA are you?
    Main System 2.2:
    Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
    (2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
    Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
    Home Theater 5.2:
    Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
    Winter Residence 2.1 (laptop system):
    Yamaha RX-485 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200
  • KLapinas
    KLapinas Posts: 608
    edited June 2014
  • scubalab
    scubalab Posts: 3,105
    edited June 2014
    Carl, I've got a meeting in Mechanicsburg next Tuesday. If I can help out some fellow polkies I can get them a little further north (State College area) for you. Would be glad to help out If I could!
  • classic carl
    edited June 2014
    scubalab wrote: »
    Thanks for the offer. If I drive more than an hour or so, my hip cramps up and starts screaming at me. Road trips are not much fun anymore.
    Main System 2.2:
    Home Theater 5.2:
  • classic carl
    edited June 2014
    Duplicate post...why can't we delete these?
    Main System 2.2:
    Home Theater 5.2:
  • george daniel
    george daniel Posts: 12,096
    edited June 2014
  • rooftop59
    rooftop59 Posts: 8,120
    edited June 2014
    No, since that is shipping from Denver. But it does appear to be the same model. :razz:
    Game Room 5.1.4:
    Bedroom 2.1
  • george daniel
    edited June 2014
    rooftop59 wrote: »
    and alot less-- 360 shipped is how I read it.
  • Polkie2009
    edited June 2014
    And BIN
  • audiocr381ve
    audiocr381ve Posts: 2,588
    edited June 2014
    Yikes.
  • KLapinas
    KLapinas Posts: 608
    edited July 2014
    Still available. Open to offers or trades
  • One sub available at this point. Asking $550 or best offer.
    Trades considered: Integrated amps, preamps, power amps, speakers, canon 7D, canon ef lenses
  • KLapinas
    KLapinas Posts: 608
    Price reduced $500 or best offer trades considered
