For Sale REL Acoustics Q201E Subwoofers (2)
KLapinas
I have a pair of REL Acoustics Q201E Subwoofers available for $1200/pair
One is like new with box, packaging, manual...
One has a few marks but only noticeable if you are looking closely
Both sound amazing
You can review the manual here: http://www.sumikoaudio.net/ContentsFiles/Q-Series-Manual(0).pdf
SPECIFICATIONS:
SYSTEM TYPE: Active ZeroQ Acoustic Suspension System with ABC® variable bass filter. Closed box, 17 litre.
IN ROOM LOWER FREQUENCY RESPONSE AT -6dB: 17Hz
AMPLIFIER INPUT IMPEDANCE: High level 100K, Low level 10K
GAIN CONTROL RANGE: 56dB
DRIVE UNIT IMPEDANCE: 4 Ohm
MAINS INPUT VOLTAGE: 115V 50/60 Hz or 230 V 50/60 Hz, subject to country
DIMENSIONS: WxHxD mm (inches) incl. feet and rear panel controls 300x328x353 (11.81x 12.91x13.90)
WEIGHT: Kg (lbs) 17(37.48)
FINISHES: Bnttex Black, Maple, Cherry, Rosenut, Walnut
FEATURES:
True 200W (continuous] discrete direct-coupled MOSFET amplifier
Forward-firing 250mm (10"), long-throw, heavy-duty driver with 7.6 kg magnet and 4 layer edge-wound voice-coil
Refined ABC® infinitely variable crossover adjustment from 26 to 106 Hz
Four position mode selector: line/LFE (0 degrees phase and 180 degrees phase)
Audiophile grade toroidal transformer
Gas-tight Neutrik high level connection for long-term consistency of sound quality
High quality, panel-mounted twin phono inputs at 0dB and +12dB (low level)
Totally discrete input circuitry for high and low level inputs
Separate volume controls for high and low-level input adjustment
Simultaneous connection of high and low level sources
Set-Safe® audibly transparent driver protection
4x ultra-rugged output devices
Double-sided glass-fibre board with plated-through holes
IEC power input socket - non-captive lead for installation flexibility
Heavy duty grille
Hand-built in Great Britain
Three year worldwide warranty
Both sound amazing
SPECIFICATIONS:
FEATURES:
Heavy duty grille
Post edited by KLapinas on
REL makes the most musical sub's out there imho. If you are looking for a quality pair of sub's, especially in a two channel setup, these are hard to beat. GLWTS!
Thanks for the support Dawgfish. They fill in the bottom octave quite nicely. They were a nice match to the Legacy Audio Classics I just sold.REL makes the most musical sub's out there imho. If you are looking for a quality pair of sub's, especially in a two channel setup, these are hard to beat. GLWTS!
I've heard this same thing time and again about REL subwoofers, a solid sender of a musical sub, fantastic craftsmanship and integrity built through and through. GLWTS!REL makes the most musical sub's out there imho. If you are looking for a quality pair of sub's, especially in a two channel setup, these are hard to beat. GLWTS! -
Polkie2009 wrote: »I've heard this same thing time and again about REL subwoofers, a solid sender of a musical sub, fantastic craftsmanship and integrity built through and through. GLWTS!
Thanks Polkie2009! Very musical subs that do a great job with movies as well! -
Bump
Wow, not interest or offers on these! $1100 for the pair
Where in Central PA are you?Main System 2.2:
Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
(2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
Home Theater 5.2:
Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
Winter Residence 2.1 (laptop system):
Yamaha RX-485 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200 -
Mechanicsburg
classic carl wrote: »Where in Central PA are you?
Carl, I've got a meeting in Mechanicsburg next Tuesday. If I can help out some fellow polkies I can get them a little further north (State College area) for you. Would be glad to help out If I could! -
Thanks for the offer. If I drive more than an hour or so, my hip cramps up and starts screaming at me. Road trips are not much fun anymore.Main System 2.2:
Home Theater 5.2:
Duplicate post...why can't we delete these?Main System 2.2:
Home Theater 5.2:
george daniel wrote: »
No, since that is shipping from Denver. But it does appear to be the same model. :razz:Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
and alot less-- 360 shipped is how I read it.JC approves....he told me so. (F-1 nut) -
And BINgeorge daniel wrote: »and alot less-- 360 shipped is how I read it. -
Yikes. -
Still available. Open to offers or trades
One sub available at this point. Asking $550 or best offer.
Trades considered: Integrated amps, preamps, power amps, speakers, canon 7D, canon ef lenses -
Bump
Price reduced $500 or best offer trades considered
