How does one clear inbox?
See title
  • WilliamM2
    WilliamM2 Posts: 4,806
    Select the messages one at a time and on the right side you should see "delete conversation", or something like that. No quick way to do it.
    In my case every PM I ever had came back with the new forum, even though many had been deleted years ago.
  • deronb1
    deronb1 Posts: 5,021
    Weird. Ok thanks
  • boston1450
    boston1450 Posts: 7,758
    Did the same here. Deleted all the time & now there back. Not sure if they get full now because i havent played around with the new set up. Stinks
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • xjghost
    xjghost Posts: 1,115
    Might be a restore issue. If they saved the old forum adn then restored it that might do that? Just a theory from someone who knows nothing.
    HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
    Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
    Additional projects: RTA 12c's
  • I have no idea how to even find the PM's anymore. Wherever they are, having fifteen years worth come back all at once isn't going to be good.
  • xjghost
    It's the little envelope icon under your nick on the right of the screen.....
  • xjghost
    The internal message system here is the worse with no way to remove select messages just a whole conversation. I just realized that fact.
