Cables (in which order of importance?)
tophatjohnny
in Electronics
Ok, so this must have been covered before but I have to ask in which order of importance do you have your cables assigned? Meaning to those that have good, better and best interconnects, which piece of gear gets the good, better and best. For me, I have the power amp, a pre amp, a Cambridge Stream Magic and a cable tv box. I'm thinking the amp to the pre outs in the pre amp should get the best, the better cables should go from the pre amp to the stream magic, and the good cables to the cable box. Is that a plan?? Eventually I will have all great interconnects, but damn things are expensive??????? lol
Best Answers
There is no hard and fast rule. What you suggest sounds reasonable, but try swapping them later and see if it gets better or worse.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I'd agree here.There is no hard and fast rule. What you suggest sounds reasonable, but try swapping them later and see if it gets better or worse.
The other thing is to think where you REALLY care about getting good quality from. I have this "feeling" your StreamMagic is where your high rez stuff starts v your cable box.
I'd tend to think you cant clean up a dirty signal, so maybe put the best on the Stream Magic so your giving the pre-amp the BEST possible signal to work with, then your second best from pre to amp. Your worst from cable box to pre-amp because who cares "as" much about TV quality v music?
But like bluefox said, you will have to tweak em as you can...
"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
here's food for thought. let's assume that the $1000 interconnect is better than the $500 interconnect from the same manufacturer.
A. $1000 B. $500
which of these combinations do you think would sound better? in which order?
1. source: A amp/pre: B
2. source: B amp/pre: A
3. source: B amp/pre: B
4. source: A amp/pre: A
in my experience in my system I would go as written, 1, 2, 3, 4.
this can all be negated by your source, preamp, amp, speaker cables, or speakers not being at the same quality level.
I guess what I am trying to say is you have to look at (listen to) everything as a system.
tough huh? but fun.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
A. $1000 B. $500
tough huh? but fun.
It depends, in the end, on the sound you like. For example: I have some AQ Sky interconnects and some AQ King Cobra interconnects. The SKY ICs are much more costly than the King Cobras. The Sky ICs also produce a brighter sound than the King Cobras.
The Sky ICs seem to my ears to introduce brightness when they are between the pre and the amps that does not occur to the same extent when the Sky ICs are between the DAC/CD player and the pre and the King Cobras are between the pre and the amps.
Maybe just my ears, but I'm not sure cost is the determining factor. You just have to trade ICs in and out and go with what you like best as you listen.
Answers
I have been advised that you should start with the source and work through the system??Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
This is a hard one. For me, i have had cables that made my rig sound like someone put a blanket over them. What source do you listen to the most after the amp / preamp? You can get some good sounding cables for not a lot of $. Doug, and Signal both have good cables for not a lot of $.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Good rule of thumb....start with the source...and build out.....
Power cords?? I think you misunderstood...keeping the cabling uniform if possible from source to end to achieve balance...that is the goal....If you are getting amplified noise from an AC source..then you have other issues...and swapping IC's or speaker wiring isn't going to remedy that....
go to Signal Cable and start there. If you can tell a difference there, then continue on the cable journey. Audioquest also makes great cables, just make sure you are aware of fake cables if buying on ebay.Shoot the jumper.....................BALLIN.............!!!!!
Thanks for the great answers. With the cables I now have in place, I think I'm good. (I said "I think") lol Anyway, the 2 sets of interconnects I have and all I need for my set up are both very high quality and while I have switched them around, I can hear the difference, while between the two higher end sets, not as much, so I'm staying with the better sounding set between my pre amp and the stream magic 6 and the other from pre to amp! Both of which are real nice ropes!! I hops this puts a major fork in my but!! I feel done!!"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
You never know how much noise you have until its gone.
Very good point. Noise in most cases is blamed on something else, misunderstood. Just like those who say "they have to see it to believe it", in this case you "have to hear the absence of it to believe it".
