Technics SL1300
boston1450
Picked this tt up last week & have been playing it since. Maybe 15+ albums. Does a great job. Has a Audio Technica sylus & Cart on it & plays quite well. Could i get some help itentify what cart model # this is TIA
Could i get some help identifying which one it is ? Thanks in advance.
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
by David WMG
Post edited by boston1450 on
Pull it out of the headshell; the model should be embossed or printed on the top side of the cartridge (where, of course, you cannot see it).
It's a pretty good one... I have one that looks just like it (and I honestly cannot remember the model -- I am just not much of an A-T fan, so it's not the kind of information I retain :- P). -
Thanks Mark. I can take it out BUT i dont have knowledge how to get it aligned up again OR the special tool to do that with.. I did remove it off the arm BUT still couldnt see letters / numbers. I looked online & sure enough numbers are on Top.Randy-Maine
by David WMG
I love my Technics TT's. They work well and don't break the bank. I'll get something nicer later but until then these do just fine. Side note. What is that you have your "system" sitting on?
https://us.v-cdn.net/5021930/uploads/editor/5e/68363q6tr6dp.jpg
I'm looking for something for my son's stuff and the more I look the more I think I need to give him mine and buy me a VTI. That however looks like it would do what I want it to do effectively and not break the bank.HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
Additional projects: RTA 12c's -
Nice table. I'm running a 1600 from that same series of Technics. Fairly robust table and more impervious to footfalls and children dancing than some of my other tables.
Sorry I can't help you with an id on the cart. I've used both a Shure M97xe and Ortofon 2M Red on mine with good success. The Red has crisper highs and the Shure tends to have a little more body and slam to the lower midbass region. Enjoy.
PS- Have you had time to play any of the R2R tapes I sent you?
-2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer. -
. Yes i have - PP&Mary & Monkeys is on the Teac in BDRM when the Mrs's is doing online college test - its my get away hide out
They all will get used often. I got probably 70 small ones & 12 10in ones for the Pioneer. Getting there & enjoy it
Randy-Maine
by David WMG
[quote="xjghost;2083856. What is that you have your "system" sitting on? .[/quote]..... Freebee rack
Randy-Maine
by David WMG
..... Freebee rackboston1450 wrote: »[quote="xjghost;2083856. What is that you have your "system" sitting on? .
[/quote]
LOL! That is exactly what I need! What kind of rack? It looks like some sort of table or end table.
From the pic, is the cart a gold color or yellow?
BTW the 565 is a solid pre with a solid phono pre. Nice setup.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's. -
The cartridge is gold. Like i stated above-id remove it but dont have the tool to align it.. The Adcom 565pre is spectacular & does quite well on phono or everything i have ever put on her. The Adcom as a whole does very well on SDA's not so well on the RTA15's i just got. I listened to it set up for a week & a no goRandy-Maine
by David WMG
[/quote]. It was a TV stand that i got free. It had a tv on it. Its wood. Light but very rugged. It had a 63lbs AVR & 40lbs amp on just bottom & another 30-40lbs on top shelf when i was running HT set up. I know its not much-but i love it. Look at antique places & furniture/yardsale Craigslist or local paper. Cheap deals out there
Randy-Maine
by David WMG
Nice table. Have no idea about the AT cart. Just got a call from Pete today on the DUAL TT I have in his shop. Looks like a go for repair. I believe it has the standard SHURE cartridge on it. OK, but not TOTL. I find myself partial to "old" school SHURES, nothing too upscale.
You seem to be selling off a lot of you stuff on CL, Randy! What's up?
What are you thinking of "upgrading". As far as I'm concerned you have some very nice set ups. Your SDA 2Bs are the more aesthetic ones than mine. Your 1Cs look mint. The Yamahas and Adcoms are doing a nice job. The YaQin tube buffer sounds pretty good. The only thing I can think about is getting a tube amp on those SDAs. Other than that, going with BIgger SDAs won't get you much, you, like I, don't have the SPACE for those to really show you what they can do?
As for me, I've been working on setting up a cheap studio for my daughter in my son's former bedroom. Picked up a cheap Insignia receiver (that is really a Sherwood 4109 rebadge for $4.99). Put two VIFA tweeters in a set of JBL 2500s. Also bought a set of Yamaha NS 25Ts as another pair of monitor-like speakers for that room from Joe for close to nothing. We're using a Blue Yeti USB mic. and she has recording software on her MAC. Next, have to buy some diffusion and foam sound traps, etc. Work in progress. Then a synth/keyboard with computer interface, and so on!
Randy... mind you I am not encouraging you to do this, but... you don't need a physical alignment jig to install (or, re-install) a cartridge properly on a Technics S-shaped arm. What you would need is an alignment protractor or a jig. You can buy such things, or you can download decently accurate jigs as PDF files from www.vinylengine.com
You do need to know the proper overhang, too... but that's easy (52 mm -- see Figs. 2 and 3 on page 3 of the manual, which you can snag at vinylengine.com/library/technics/sl-1300.shtml)
That said, the headshell on the 1300 is kind of funky; with the single screw overhang adjustment. Apparently not all alignment "standards" can be achieved with this headshell... but any standard-issue headshell will (should!) work on the arm.
Just sayin'...
Can't be sure but it looks like an AT 15SS OR 20SS. Same cartridge body will support both styli.
Because I am The Pumpkinking
i will be seen Pete next week. He does good work. Gotta drop off a repair. As far as getting rid of stuff-my closets/basement/barn is overfull & im eying a Integrated tube ampNice table. Have no idea about the AT cart. Just got a call from Pete today on the DUAL TT I have in his shop. Looks like a go for repair. I believe it has the standard SHURE cartridge on it. OK, but not TOTL. I find myself partial to "old" school SHURES, nothing too upscale.
cnh
& the funds will help
Post edited by boston1450 onRandy-Maine
by David WMG
.thats what i was stating above. I dont have one & i need to get my read on before i do itmhardy6647 wrote: »Randy... mind you I am not encouraging you to do this, but... you don't need a physical alignment jig to install (or, re-install) a cartridge properly on a Technics S-shaped arm. What you would need is an alignment protractor or a jig. You can buy such things, or you can download decently accurate jigs as PDF files from www.vinylengine.com
Just sayin'...
its about time i learned how to if im going to use TT's
Randy-Maine
by David WMG
. Thanks Pman . I think your correct. Just looked at the 15ss & it looks identical.pumpkinman wrote: »Can't be sure but it looks like an AT 15SS OR 20SS. Same cartridge body will support both styli.
Randy-Maine
by David WMG
I bought a SL1360 from someone in Boxborough several months ago. The cart looks similar to mine (AT15Sa). Although as others have said it could also be the 20.
http://www.vinylengine.com/turntable_forum/viewtopic.php?f=19&t=64679
It is a nice cart with a Shibata stylus. I didn't know the amount of usage so I decided to get an AT120ET.
It a nice start on the vinyl journey, but I have much further to go. Enjoy.
