RTA 15tl rebuild...1.75 vs. 1.80 inductor
myron horn
Ready to do a crossover rebuild, as per the Decato posts......heres the question, Decato specifies a 1.75 mh inductor....BUT....after looking at Sonicraft and Madisound, I can only find 1.8mh inductors. I have heard you can unwind an inductor, but I have no way of knowing just how much to take off....Any input on this?
You'll need an LCR Meter, or see if Soniccraft or Madisound will do it for you. You'll most likely pay a premium for them to do it.Home Theater/2 Channel:
dhsspeakerservice.com/ -
Checked out your website.....would you consider redoing them?
Are you talking about the inductors, or the entire crossover?Home Theater/2 Channel:
I really doubt you have to worry about .05 difference, I would bet it's within tolerance..
Simply the inductors westmassguy.....After all, the rest is my weekend project as soon as harvest wraps up here!
Contact me directly via my website, 2nd page. Have them shipped to me, and just pay the return postage. I'll take care of them for you.Home Theater/2 Channel:
