What is your favorite peace of gear?
Seriously though, I really love what my SMS-1 does for my bass response. Everyone should at least try a sub EQ, cleans up that low end.
I know it's not high end, but this:
That's a T-1, yes (not a T-7)?
Neither's a T-2, of course, but both the T-1 and the T-7 are beautiful and capable tuners. I'd love to have any of the above (or, heck, as long as I'm dreaming, a CT-7000)! -
I like all my stuff...
SDA 1.2tl's
W4S gear, Amp's, Pre Amp, DAC..
OPPO 105
VPI TT
Jolida Phono Pre..
MIT Shotguns through out..
Etc.. -
Im hoping the Dali Mentor 2s heading this way will be!
My Tyler Acoustics Linbrook Signature System speakers, followed closely by my recently acquired Odyssey Kismet amp.
2-Channel System
Analog: VPI Traveler TT, Audio Technica 150MLX, Pro-Ject Tube Box DS
CD Player: Jolida JD-100 Preamp: Cambridge 840E Amp: Odyssey Kismet Stereo
Spkrs: Tyler Acoustics Linbrook Signature Systems -
Mine would have to be my Valve Amplification Company (VAC) Standard LE preamp. This pre is the core of my system and has an outstanding phono section. A remote volume and mute also help make it convenient. And the sound...... Only way it leaves is to be replaced by one up its line (and they are a little to $$$$$) so we will happily coexist for a long time.integrated w/DAC module Gryphon Diablo 300
server Wolf Alpha 3SX
phono pre Dynamic Sounds Associates Phono II
turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
speakers Rockport Mira II
cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
rack Adona Eris 6dw
ultrasonic cleaner Degritter -
Obsession18 wrote: »My Tyler Acoustics Linbrook Signature System speakers, followed closely by my recently acquired Odyssey Kismet amp.
Never heard a Kismet, but would like to. I had my Stratos Stereo modded by Klaus and it's closer to a Kismet than a Stratos now, but without the case. How do you like your pre? Is it a good match with the Kismet?
"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
drumminman wrote: »Obsession18 wrote: »My Tyler Acoustics Linbrook Signature System speakers, followed closely by my recently acquired Odyssey Kismet amp.
I've been happy with the Cambridge 840E and its a good match with the Kismet, but in the back of my mind I've been thinking tube pre, like a Rogue Audio 99 Magnum. My fear is that that the Rogue unit won't provide the improvement I'd expect, I'm quite happy with the way my rig currently sounds.
Klaus told me I could safe about $400 putting the Kismet in a Stratos case, but I opted to stay with fancy Kismet case, my only complaint - that bright as the SUN blue led light.2-Channel System
Obsession18 wrote: »I've been happy with the Cambridge 840E...
Before I bought my Pass gear, I was using an 840E, and two 840W amps in bridged mono mode. This was the system I used to upgrade my power and cables to Shunyata, and I was constantly amazed at how much better it kept getting. For a total price that is less than my Pass XP-20 pre, the Cambridge gear can easily hang with the Pass. I suspect the new Cambridge 850 line is a bit better. If anyone wants to experience a real and decent high-end system for only $7k then get the Cambridge pre and two amps.
Three 20 amp circuits. -
My stash of 50's and early 60's tubes. Seriously, they make a difference.
Also my MIT Shotgun S3 speaker and I/C cables.
This is my fav vintage set upRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
boston1450 wrote: »
That looks dangerously top-heavy :- O I hope you have no rambunctious pets (or rambunctious children)...
That looks like a Yamaha TC-520 cassette deck? :- )
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
My B&K Reference 200.2 is the first piece of high-ish end gear I ever bought. I've tried a few other amps, but this just keeps making me put it back in my rig. I think I'll have to spend a decent amount more to best it.
The LSiM 705's have a pretty good chance to become my favorite, but I only listened to them for a couple days before I tore my system apart. I haven't had the chance to put it back together and it's been a couple weeks!!!
I'm going through withdraw
:'( 2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
So hard to say. I like every thing in my "wall of shame".
Would like to test the waters on that reel/reel thing. -
yup tc520. If you notice the feet are off the r2r & its quite sturdy. 4 inches on each side & 8 on f&b. Little ones are older n chihuahua's are pretty good. Thanks for mention. Listened to the Teac today. ELO & Monkeysmhardy6647 wrote: »boston1450 wrote: »
Randy-Maine
by David WMG
I've got the Otaris all three functioning (gave one to another Northern New England vacuum tube hifi guru, which seemed only fair) : -)
My Carver designed DIY monoblocks are hands down my favorite pieces of gear, followed closely by a very special pair of 1.2TL's with full mods. The Yamaha PX-3 and Pioneer D9-MkII SACD are both a very distant third place tieThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Hey, nobody said it had to be "high end" to be your favorite.I know it's not high end, but this:
The T-1's not exactly dog food. No, it ain't no T-2 ( or CT-7000), but it is a beautiful & very competent piece.
That it is.....almost looks Nad-ish with those buttons, I like it.HT SYSTEM-
lsi 9's -
oh heck I'm apparently on auto-repeat :- P
I have to agree that synergy with a system is the ideal, but I just sent away my NAD 1020 preamp to be refurbished be Leesonic at AK. The preamp that I got back has nothing to do with the one I sent.
The 1020 will be my "new" favorite piece of gear for a while, and the NAD 116 pre will be hitting the block very soon.Polk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2 -
Usually its the new addition to the mix, so I'll have to say my new LSiM703's. These bookies are crazy good!Anaheim Hills CA,
2 Channel: Rogue RP-5 / WireWorld Electra power cord / Marantz TT-15S1/ Ortofon - Quintet Black MC / Marantz NA8005 DAC / W4S mAmp's / Synology DS 216+ll-4TB / Polkaudio LSiM703 -
I started this thread with:Mine is two parts, or five if you count the cables. I love my Bryston BDP-1 digital file player, Auralic Vega DAC, Shunyata Anaconda AES digital cable, and two Shunyata Alpha Digital power cords. This combination allows me to truly enjoy more music, and get the best performance from the rest of the gear.
A few weeks ago I upgraded the Alpha Digital power cord on the BDP-1 file player to the new Shunyata Sigma Digital power cord. Wow! This system is now so quiet and freaking precise and detailed that it is scary. I simply have never heard it sounding so good. The Sigma is a fantastic power cord for digital components. The digital front end is still my favorite piece of gear. Between the sound, versatility, and convenience nothing else comes close for me.
Have to say my Liberty Audio B2B 100, but it would not be a party without the Cambridge Audio Stream Magic 6 & the Cambridge 840e pre!
My Dahlquist DQ-20's.
I use DQ-10's, Magneplanar MMG's, Meadowlark Kestrel Hot Rods, Quad 11t, and Boston Acoustics A-150's in other systems around the house, and at other times, but I don't think I will ever get rid of the DQ-20's.Norh ACA-2B tube pre, Sumo Andromeda SS amp. Magneplanar MMG speakers, M&K MX1250 Subwoofer, Pro-Ject RM1.3 Genie TT with Sumiko Pearl MM cart., Keces DAC, Cambridge Audio Azur 640c CD player -
The one constant for me over the last decade has been a Sonic Frontiers Line 3 preamp, upgraded soon after I got it to SE+ specs by Chris Johnson:
http://archive.anthemav.com/OldSitev1/review/line-3.html
The tubes last around 3 or 4 years in it, so the cost of retubing with 12 new tubes every few years isn't that big a deal. The rear two tubes (6DJ8 or 6922) are the important ones.
I also have a Parasound JC-2BP preamp, which is also excellent in its own way and very quiet but missing the soul that a good tube preamp has.
