Musical Fidelity A3CR Amp
In my short time in audio, I've learned that it is not always quantity but quality........in this case watts.
The Musical Fidelity A3CR power amp has 120W....would that be enough to be an end-game amp for my LSiM 705's?
Right now I'm in a state of fluctuation with my main rig. I'm selling an Anthem 225 integrated that sounded pretty good with the 705's, but not perfect. I'm considering going back to my B&K Reference 200.2, which I know will sound good, because I used them with my LSi15's.
But, now I'm considering a MF A3CR Pre and Power combo...
Please help!!
Thanks,
Paul
    F1nut Posts: 51,885
    It might be, but only one way to find out.
    MF makes very linear amps and the choke regulation is icing on the cake.
    treitz3 Posts: 20,046
    Very musical amplifier, linear and authoritative. You can buy the A3CR with confidence. While it may not be my own personal end game amplifier, I can say with complete confidence that I went through 30 or 40 tube and SS amps before this one hit the rig and it has stayed ever since (for years). Can't speak for the pre though, never heard it before.
  • hochpt21
    hochpt21 Posts: 5,423
    Is it powerful enough to push the 705s properly? I don't often listen at reference levels...but sometimes do.
    Short answer ....yes.
    msg Posts: 10,452
    hochpt21 wrote: »
    Well? Was it enough to push the 705s properly? B)
    (I'm helping Brian with his research, which will in turn help me with mine at some point.)
