Connecting 2 subwoofers with a 5.1 AVR
Hello,
My questions is basically the "Discussion Title" in question form.
I have a Denon AVR e300 avr (5.1 channel) and a Dayton Audio SUB-1000, using mediabridge subwoofer cable, and splitter to left/right RCA. Other speakers don't really matter, but they are pioneer towers (A. jones series) and B652 surround (avr has all speakers set to small, in my bedroom set-up - I didn't need expensive surrounds, so I went the the B652s).
I am curious if I can use the high level inputs/outputs to connect another sub (just assume the 2nd sub is another SUB-1000 to make things simple)
I didn't state the manufacturer of the B652s because if you do not know or own a pair, you are missing out.
  • The reason I am posting this home theater question in the polk forums, is because my car audio is 100% polk :p - I have the DB series in my truck, which is amazing for the price. Got majority of it on sale at frys electronics.
  • Hermitism
    Hermitism Posts: 4,329
    At one time I had two subs connected to my 7.1 channel AVR. I connected a splitter to the "sub out" on the AVR and ran a subwoofer cable to each LFE input on each sub.
  • I have 2 subs connected to the 5.1 AVR in my sig. I use a splitter from the sub out, connecting one RCA to the right sub and the other to the left sub.
    Main System 2.2:
    Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
    (2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
    Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
    Home Theater 5.2:
    Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
    Winter Residence 2.1 (laptop system):
    Yamaha RX-485 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200
    Since you already have a splitter in line, simply unplug one from the one sub and run to the other subs input. You do not need both left and right inputs connected to each sub, one is fine....doesn't matter left or right.
