How to post a picture
I seem to not be able to post a picture and not having any luck searching threads for the answer.
I select the Attach image/file icon and choose browse, find my pic and select it but it never comes up in the post.
Appreciate any directions.
TIA,
Tracy
    mhardy6647 Posts: 34,936
    If the image file is large, it takes a while for it to load. There's a little light blue "progress bar" that shows the progress of the upload -- I think it's at the top of the box in which one types the message text. Be sure to wait until it finishes; a BB coded link should appear; i.e., a forum URL bracketed by "IMG" (and "/IMG) tags in square brackets.
    For best results : - ) though, you might want to upload your photos to an image hosting site such as FLIKR. Google has one too (the erstwhile PICASSA); I cannot recommend PHOTOBUCKET, as in its free form the bandwidth is too limiting (10 GB). FLIKR gives us a terabyte : - )
    The nice thing about those services is they have cut and paste links for BBs such as this; no fuss, no muss, no bother.
    HTH, as they say.
  • thsmith
    thsmith Posts: 6,082
    Thanks, maybe my problem is the files are too large where before it would tell you that.
  • thsmith
    Problem must IE, Google Chrome works fine.
    edited September 2014
    Here, let's give it a go.
    I am going to select and upload a photo...
    EDIT: OK, here's a peek behind the curtain : - )
    Click the "Attach Image/File" button above (looks like a sheet with the corner folded):
    I then picked a file from my computer; a JPG of a Yamaha CA-44 amp I 'borrowed' from someone at AK : - ) and hit the "Choose Files" button (see screenshot above) to upload it...
    OK, this is the"Progress bar" you should see:
    This is the result:
    ... and the final result displays the image (which is now part of the Polk Forum's database)! : - )
    If, instead, I want to use a photo on a hosting service such as FLIKR, I can cut and paste a properly formatted and parsed link to display the image that looks like this:
    ... and the result of that paste...
    14940472942_6c984cbf55_b.jpgcelestas by mhardy6647, on Flickr
    Post edited by mhardy6647 on
  • thsmith
    The problem with IE is I am not getting the pull down when I select the arrow to the right of the ICON but do with CHrome. Thanks for your help.
    good old IE (aiyeeeeeeeeee!)
    ... maybe a popup blocker is enabled?
    tonyb Posts: 33,068
    If ya want to learn how to post pics....send Rick88 a PM.
  • Thorton
    Thorton Posts: 1,324
    tonyb wrote: »
    Training from Rick should be a requirement before gaining access to the site.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
    la2vegas wrote: »
    Parasound.
    eh?
  • VCoak
    VCoak Posts: 200
    TEST.
    W4S SX-1000, Adcom gfp-750, Polk 1.2tl, W4S DAC 2 DSDse, 2012 mac mini (mod), JRivers ver. 19, WD Cloud NAS 2 t.b., Monster Cable AVS-2000 signature, Doug's Alpha I/C & Doug's biwire 6' speaker cables
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited January 2015
  • StevieB
    StevieB Posts: 257
    McCormack DNA-1 Amp, Parasound Halo P5 Pre Amp, Denon DVD 2900 CD player, Adcom GDA 700 DAC, VPI Traveler TT with Denon 103R cartridge, Lounge Audio MKiii phono pre and Copla SUT, Polk SDA SRS 3.1 TL speakers, Tributaries series 8 IC's and speaker cable.
  • gurot1
    gurot1 Posts: 519
    lsim705,lsim706c,lsif/x(4)+mc80(atmos)
    rti6,csi5,fxi5
  • StevieB
    StevieB Posts: 257
    test
