PSW10 super quiet?
So in my quest to upgrade from some cheap computer speakers I've managed to put together the following: Sherwood RD-7106 receiver, Polk RT800's up front, can't remember the model for the rear's, and I just acquired my first sub, the PSW10. Since my receiver is powering the front and rear speakers I plugged the sub into the pre-amp on my receiver. At first I thought the sub wasn't working at all, but I did a tone test and definitely got sound. I have to turn the volume on the sub to Max to actually hear it at all when I play music though. I also have the bass on the receiver turned way up. What am I doing wrong?
I tried using a 3.5mm jack from my iphone to the sub RCA jack and it's quite loud when I have the volume turned only a 1/3rd of the way up, much much louder than when I go through the receiver. Is my receiver the problem? It wouldn't seem like it since the sub is self powered. I've tried several different RCA cables, one was a y split cable. I also have the low pass turned all the way up on the sub. Can't figure out what's going on and I have no headroom for adjustment other than trying to turn the bass on the receiver even higher.
  • hochpt21
    hochpt21 Posts: 5,423
    The psw10 isn't worth having. I know....because I have one. I tried to run it in a 10x20 room and had the same results as you.
    It might be ok in a tiny room, but again...I don't think its an item worth owning.
  • hochpt21
    Edit...saw that you said it got loud with the phone. No idea, but whenever I ran mine through a receiver it was not good.
  • Tbone289
    Tbone289 Posts: 661
    edited September 2014
    My suggestion would be to try running the speaker outputs of your receiver to the speaker-level inputs to the sub, rather than the line-in inputs. I've had much better results connecting this way to Polk entry-level subs such as the PSW-10 and PSW-202.
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
  • classic carl
    Tbone289 wrote: »
    What he said...Connect the main speaker outs to the sub and then connect the sub speaker outs to the main speakers. No RCA plugs needed. Use speaker wire.
    Main System 2.2:
    Proton AA-1150 ~ Yamaha C-4 ~ (2x) Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
    (2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2
    Teac R-919X ~ Sansui D-X111R
    Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
    Winter Residence 2.1 (laptop system):
    Yamaha A-S301 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200
