Marantz 2270
hochpt21
in Electronics
Would a Marantz 2270 work with my SDA 2a's?
Yup
And it will sound sweet too.My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
What would be the smallest WPC that I would want to go in the Marantz line to still drive my SDA 2A's in a small room?2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A
I use my 30 watt tube amp in a small room and can't go past 11:00 on the vol k n o b.. watts don't mean squat and it is current that is the desirable quality. Provided the 2270 is in spec it will give you what you seek. The 2270 is recognized as one the best of the 22xx receiversMy New Year's resolution is 3840 × 2160
I hooked up my Marantz 1060 (30wpc) and 1150 (75wpc) on my 1Cs and CRS+ and liked them a lot. Never really yearned for more power.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
As with all polk (vintage) speakers imho and experience "the mo power the better, you cant have too much power for them only too little!!! They may work with less however with more they will "get up and dance"! So give them as much as you can afford and go from there! I have driven my rta12c's with 100w, 200w, 280w , 400w and now 500w. 500w is much better!!!Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
I hooked my Marantz 2252b @52wpc to my 2b's it was ok at low volume but as i raised it to 10:30-11:00 on the dial it just sounded distorted,like it was going to start to clip. 15mins later i hooked up a Yamaha Cr1040 @80wpc & it did pretty good surprisingly. Ive played around some, but find its just better with more power as we all read here.Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
