Marantz 7005 for my RTI-12
Hello everybody.
I have a system with 2 RTI-12(L,R) CSI-5 center, PSW-125 subwoofer and rti-a1 sorrounds.
My avr is a Marantz 7005.
I'm wondering whether or not it's worth buying a power amplifier.
When I use the towers in stereo to listen music ( generally I listen to at a moderate volume), it sound good for me, but my question is:
If I add a power amplifier like the EMOTIVA XPA-2, it will improves the sound at moderate volumes (at high its clear to me that it will do)??
As much as I read so far, it is unclear whether increasing the wattage improved sound quality on my RT-12, which we all know are very hungry of power.
Thank you all in advance for your support and feedback.
Polk RTI-12
Polk PSW-125
Polk RTI-3
Polk RTI-A1
AVR Marantz SR7005
Turntable Denon DP-300F
Power Console Belkin PureAV
Denon DVP-1610 Blue-ray/DVD/CD
Mediabridge ULTRA Series Speaker Cable
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited August 2014
    Yes adding a power amp will increase sound quality at moderate volume. It will help in surround mode as well, as it will take a large load off the avr and allow the other channels to perform better.
    pitdogg2 Posts: 27,317
    This^^^^^^^^
