Need help with PC setup
KrazyMofo24
I'm currently using the Haydn's with a Cambridge Azure 650av2. I'm also using this PC for my headphone setup which is the Q701's with a starving student tube amp.
My dac is the AQ Dragonfly and using a 3.5mm to RCA adapter to connect to either the Cambridge for the speakers or the tube amp for the headphones.
I'm looking for an easy way to switch between the two. Right now I'm having to swap the RCA cables around. I was considering getting another dragonfly and just switching using Windows. That'll also make it easier for me to take one of them to work to listen there.
If there is a cheaper option that won't hurt the sound quality would like to be switch between them similar we normally do it with preamps. Is there a way I can get it routed through the cambridge or is there another product like a switch I can use?
Setup:
2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI
These aren't bad
http://www.amazon.com/Sescom-SES-IPOD-AB-Stereo-MP3-Player/dp/B005TE7GP4 but you will need an additional set of 3.5mm IC'sMy New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Thanks Mikey I think that's exactly what I'm looking for.Setup:
PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI -
http://www.bhphotovideo.com/bnh/controller/home?O=&sku=718845&gclid=Cj0KEQjwveufBRDlsNb3kb-twMIBEiQASNH0xpiQjVl4CJtHXnl6PvKTpowxSj56amfcnRs9jwcknQ4aAhrt8P8HAQ&is=REG&Q=&A=details
I think I'm going with this one. I rather do it at the RCA cables to avoid buying another RCA to 3.5mm adapter.Setup:
KrazyMofo24 wrote: »http://www.bhphotovideo.com/bnh/controller/home?O=&sku=718845&gclid=Cj0KEQjwveufBRDlsNb3kb-twMIBEiQASNH0xpiQjVl4CJtHXnl6PvKTpowxSj56amfcnRs9jwcknQ4aAhrt8P8HAQ&is=REG&Q=&A=details
I have that one... pretty solid for $36...
