Need help with PC setup
KrazyMofo24
KrazyMofo24 Posts: 1,210
edited August 2014 in Going Digital
I'm currently using the Haydn's with a Cambridge Azure 650av2. I'm also using this PC for my headphone setup which is the Q701's with a starving student tube amp.
My dac is the AQ Dragonfly and using a 3.5mm to RCA adapter to connect to either the Cambridge for the speakers or the tube amp for the headphones.
I'm looking for an easy way to switch between the two. Right now I'm having to swap the RCA cables around. I was considering getting another dragonfly and just switching using Windows. That'll also make it easier for me to take one of them to work to listen there.
If there is a cheaper option that won't hurt the sound quality would like to be switch between them similar we normally do it with preamps. Is there a way I can get it routed through the cambridge or is there another product like a switch I can use?
Setup:
2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI
  • Mikey081057
    Mikey081057 Posts: 7,127
    edited August 2014
    These aren't bad
    http://www.amazon.com/Sescom-SES-IPOD-AB-Stereo-MP3-Player/dp/B005TE7GP4 but you will need an additional set of 3.5mm IC's
    Garage | Polk Monitor 5B's
  • KrazyMofo24
    Thanks Mikey I think that's exactly what I'm looking for.
    Setup:
  • KrazyMofo24
    Setup:
  • Mikey081057
    I have that one... pretty solid for $36...
