How do you repair a speaker's grill post ?
When you remove the grill from the speaker, there are chrome posts the grill attaches to.
The inside of the post appears to be made of plastic or ceramic with a chrome coating.
When a post breaks off, what type of adhesive is recommended to reattach it ?
Best Answers
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    Answer ✓
    As tight as those grills go on I am not sure if any type of glue would hold it back on. I would just put the grill back on without it and, leave it on. Otherwise you may try gorilla glue or similar. I successfully repaired a post on a JBL center with the stuff, but they were not near as tight as the Polks.
  • soundfreak1
    soundfreak1 Posts: 3,414
    Answer ✓
    Should be able to remove with needlenose or maybe drill out and replace. Have dove many both ways.check with olk for specs and replavements? Bought ones for my rta 12b's and other poljs fron parts express.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
Answers
    F1nut Posts: 52,000
    Again with the "Answered" c r a p.
    You can't fix a broken post, only replace it.
