How do you repair a speaker's grill post ?
When you remove the grill from the speaker, there are chrome posts the grill attaches to.
The inside of the post appears to be made of plastic or ceramic with a chrome coating.
When a post breaks off, what type of adhesive is recommended to reattach it ?
Best Answers
As tight as those grills go on I am not sure if any type of glue would hold it back on. I would just put the grill back on without it and, leave it on. Otherwise you may try gorilla glue or similar. I successfully repaired a post on a JBL center with the stuff, but they were not near as tight as the Polks.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
Should be able to remove with needlenose or maybe drill out and replace. Have dove many both ways.check with olk for specs and replavements? Bought ones for my rta 12b's and other poljs fron parts express.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
Answers
Again with the "Answered" c r a p.
You can't fix a broken post, only replace it.
