Polk FS Speaker Selection vs. Room Size
dadboni
dadboni Posts: 1
edited August 2014 in Speakers
My home theatre/music room is 12' wide and 25' long. My wife and I sit 15' from the tv/speakers and face the 12' wide wall. We have TSi300 speakers, center channel, and surrounds that are placed behind us. All is powered by a Yamaha RX-V473. Are the TSi300 speakers adqequate for the room size or should I be looking at upgrading to TSi400, TSi500 or other?
Thanx
Post edited by dadboni on
  • Emlyn
    Emlyn Posts: 4,825
    edited August 2014
    The larger speakers would offer somewhat better lower frequency reproduction, but not much else compared with what you already have. Have you considered adding a good subwoofer though? May be a better bang for the buck choice in the long run if you'd otherwise stick with the same speaker line.
    txcoastal1 Posts: 13,519
    edited August 2014
    That Yamaha is a low watt output receiver that really can't efficeiently run larger speakers. By incorporating a GOOD sub you will get the a much better home theater effect, plus the sub has its own amp
