yaqin cd2 and vincent po 8 phono preamp
laotzu61
I was wondering if anyone may know if I can use my yaqin cd2 tube buffer in conjunction with the Vincent po 8 phono preamp and, if so, how would I connect the in and out cables? thanks.
"The symbol is not the reality"
Post edited by laotzu61 on
Isnt the vincent phono preamp already tube?
If not, turntable to the vincent, vincent to the cd2 cd2 to your receriver or preamp. Btw. Are you using a receiver or integrated or seperate amp / pre?Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's. -
The reason why I ask, when I was using an integrated amp, it had pre out and amp in. Thats where I found my cd2 most effective.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
no, the poh-8 is not, altho Vincent does make one that does have a tube. I'm currently running a parasound hca-1200 with a parasound php-850 pre. and thank you."The symbol is not the reality" -
try it between the pre and the amp. For me when I ran one it made one heck of a difference.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
nce.
how would I connect between amp and pre?"The symbol is not the reality" -
2 analog rca cables from the pre's front left and right outputs to the CD2's inputs....then 2 more rca cables from the cd2's outputs to the amps inputs.HT SYSTEM-
lsi 9's -
gotcha. and thanks. been switching over to all zu audio cables, and think they're the cat's meow."The symbol is not the reality" -
I picked up a cd1 & cd2 here on CP & really enjoy them & notice a big difference. For the price you can go wrong. I play around with different tubes
Enjoy Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
boston1450 wrote: »I picked up a cd1 & cd2 here on CP & really enjoy them & notice a big difference. For the price you can go wrong. I play around with different tubes
Enjoy
mt cd2 came with mullard 8100's. I picked up an extra pair nos, I was so impressed."The symbol is not the reality" -
sorry. above should read "mullard." I'm not using ducks
those are nice tubes. Adds alot to the mix. I have been using Voskhods & Mullards on & off. They both seem great with the SDA's. I just switched over to the RTA's & need to get a listen to the Mullard M8100's for a bit & see how they sound on those speakers. Hard one as the SDA's just seem much better. Rolling tubes in these little guys are fun & you do notice a difference. Well worth the coinmt cd2 came with mullard 8100's. I picked up an extra pair nos, I was so impressed.Randy-Maine
by David WMG
Voskhods and western Electric on mine. Both fantastic results.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
I had an opportunity to pick up a matched pair of the voskhods from a guy on the site some time ago, and had to pass at the time. I can't recall who it was, but if he's reading this thread and still has them, I would like to try them out."The symbol is not the reality"
