Please measure your SDA SRS 1.2tl
MarkMcC
As posted previously i am in the process of rebuilding cabinets for my SDA SRS 1.2tl speakers (cabinet lost in flood). I have been trying to get the cabinet specification but no luck to date. If possible could someone how owns a pair please measure the following measurements on their speaker and post finding on this thread. I live in Australia but can convert inches to millimetres.
Refer attached drawing for measurement requirements.
A = Top of speaker to top of mid driver
B = Top of speaker to top of treble driver
C = Side of speaker to side of mid driver
D = Side of speaker to side of crossover plate
E = Bottom of speaker to bottom of crossover plate
F = Side of speaker to side of bass driver
G = Bottom of speaker to bottom of bass driver
H = Bottom of speaker to bottom of mid driver
This would be most helpful. Thank you.Polk SDA SRS 1.2tl.pdf
Post edited by MarkMcC on
Come on you 1.2TL owners, let's help this guy out.Political Correctness'.........defined
President of Club Polk -
I will take measurements in inches later today.SDA SRS 2.3TL's
SDA 2B TL's -
^Good man^Political Correctness'.........defined
Thank you, Thank you.
Ok, I will do my good deed for the day!
My speakers are a late run (1992) SDA-SRS 1.2tl. The total height of the cabinet, not including the feet, is 63 3/4". My end caps are a little thicker than those used on earlier models. They are 1 1/8" thick. The measurements below do not include the end caps, since they are not part of the internal volume. The internal cabinet is 61.5" tall and 20" wide, since the 3/4" side panels are detachable.
A = Top of speaker to top of mid driver - 2"
B = Top of speaker to top of treble driver - very close to 6"
C = Side of speaker to side of mid driver - 1 7/16" (my cabinets are not perfectly symmetrical, one side is closer to 1 3/8")
D = Side of speaker to side of crossover plate - 2 1/4"
E = Bottom of speaker to bottom of crossover plate - 22"
F = Side of speaker to side of bass driver 2 3/8"
G = Bottom of speaker to bottom of bass driver - very close to 4"
H = Bottom of speaker to bottom of mid driver - 2 3/4"
It would be great if someone else can confirm these numbers.
Hope this helps,
Brian -
It's a rainy day here in Ct. so I went and measured my 1.2tl's. The measurements do not include the side panels or the end caps so I could get a more accurate measurement A. 2" B. 5 15/16" C.1 7/16" D.2 1/4" E. 21 15/16" F. 2 1/2" G. 4" H. 30 11/16". Good luck to you and I hope this helps
I should also mention that while the cabinet is 13 1/8" deep, you should subtract 3/4" + some overhang from that for the grill. So, the actual cabinet used for determining the internal volume is 61.5" x 20" x 12 1/4".
Woops; Looks as though I was a few minutes late with my tape measure. At least our measurements are very close except for the last one; H.
Thank you sooooo much people. Now I have a project and a half. Will post pictures of finished product.
Thank you all.
M. -
treble driver....?
thats a new one...Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's -
My fault on H. 2 3/4" is the distance between the bottom of the lowest driver and the top of the crossover panel. H, as originally specified, should be 30 3/4".
A = 2 in
B = 6 in
C = 1 ½ in
D = 2 ¼ in
E = 22 in
F = 2 3/8 in
G = 4 in
H = 30 ¾ in
Note: The measurements do not take into account the top and bottom end caps or the side panels.SDA SRS 2.3TL's
SDA 2B TL's -
Good job, guys.Political Correctness'.........defined
