New Stands
Mikey081057
Mikey081057 Posts: 7,127
edited August 2014 in 2 Channel Audio
Got a new pair of stands today for my 703's.
My Skylan 28" stands were a bit hi in my current room and I found these relatively inexpensive beauties.
http://onlineshoppinghouse.com/pd3408/transdeco-td24b.php
The are easy to put together and very sturdy with nice spikes and a very thick/heavy glass base. The appear to knockoffs of the Lovan's but about half the price and they are available.
Garage | Polk Monitor 5B's
Post edited by Mikey081057 on
    F1nut Posts: 51,965
    edited August 2014
    Just so you know, Noel at Skylan will sell you shorter or taller posts that you can easily swap with your current ones.
  • Mikey081057
    edited August 2014
    Good to know... I am going to use them in the BR rig for now and will see how they fit when I move to new house...
    EndersShadow Posts: 17,719
    edited August 2014
    Looking nice man.
    If I had to do stands, I'd likely take a hard look at these (VTI VSP Series 24 inch Speaker Stand).
    Based mostly on this really good review thread here
    Another here
  • pyrocyborg
    pyrocyborg Posts: 524
    edited August 2014
    Looks nice.
    Speakers: Polk Audio LSiM 705, LSiM 703, LSiM 704c
    Receiver: Denon X3500H
  • oldrocker
    oldrocker Posts: 2,590
    edited August 2014
    Not well versed in quality stands, hope they serve you well. That Marantz in the background, man o man thats gorgeous.
    Some day I'll get one!
  • Mikey081057
    I put some sorbothane feets on top plates today...sorbothane must be petrochemical terminology for the ****!
