Another computer issue
Jhayman
I put some files on a brand new USB key for a friend, now he calls me and says the USB key is not showing up in his computer, but shows up in mine no problem..
USB key should be formatted as fat32 correct?
Or ntfs?
Any suggestions would be awesome..
Or ntfs?
Post edited by Jhayman on
Well he brought it back over and now it does not show up in my computer either..
I think it's a defective stick..I'll return it tomorrow..
ThanksATC SCM40's,VTL TL 2.5 Preamp,PSB Stratus Goldi's,McCormack DNA 500,McCormack MAP-1 Preamp,Pro-Ject Xtension 10 TT,Ortofon Cadenza Red/Nordost RedDawn LS Speaker cables, Bryston BDP-2, Bryston BDA-2,PS Audio AC-3 power cables -
I had one go bad, like you said windows did not even recognize it. I was a cheap one though from Frys Electronics. Just picked up a Silicon Power 64GB Firma ZN F80 USB 2.0 Flash Drive, Gray Aluminium (SP064GBUF2F80V1S) from amazon for $25.00, really nice and has a all metal case. The 32Gb was $15.00, if you were looking to purchase a new one.
good luck -
many times with USB people forget it is a electronic device and is subject to power charges. What happens in most cases is the person puts in the USB while a system is running and small amount of electrical charge surges and wipes the USB out making it useless, or people yank it out without going through the steps of safe removal from a system. 9 out 10 times its user error!Family Room HT 7.2/i]:Vizio Oled55h1 Pioneer Elite SC-LX502 Pioneer Elite BDP 85FD Eversolo DMP A6 Panamax M5300-EXSpeakers Fronts Fluance XF8L Center Polk Audio S35 Side Surrounds Fluance bipolar Rear Surrounds FluanceXF8 Bookshelf Subs SVS PB4000 x2 Living room 2ch: Crown Xli 1500 amp x2, Teac EQ MKII FX Audio X6 Mk II DAC Squeezebox Touch Polk Audio R700 Speakers Panamax M5100-EXOffice media room:Vizio M50Q6 50" Pioneer Elite VSX LX301 Eversolo DMP-A6 Polkaudio R600 Towers Polkaudio Center R350 Panamax M4300 Monoprice 12" subMaster bedroom:Vizio M55Q7 Pioneer Elite VSX LX302 Pioneer Elite BDP 85FD Squeezebox Touch Fluance Signature Bookshelf fronts, Rears Fluance Signature Bipolar Polk Audio CS10 center Monoprice 12" sub Panamax M5300-EX
