Computer keyboard issue
Jhayman
Upon a reboot my keyboard somehow decided to default a different keyboard layout..
Now when I want to type something into Google I get no letters but the "e" key ejects my DVD tray and the "p" key open the printer window and so on..
Does anyone know how to change these setting back, I have been to keyboard layout and selected restore defaults but it did not work..
Post edited by Jhayman on
It sounds like you've got the control key somehow activated. I'd start by popping the caps off your control keys and see if they're mashed in.
Hit the Ctrl alt and windows keys a few times eachMain Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Thanks for the help guys..
I just pressed the windows and ctrl, alt keys a few times that seems to have fixed it..
Not sure why I did not try that before.ATC SCM40's,VTL TL 2.5 Preamp,PSB Stratus Goldi's,McCormack DNA 500,McCormack MAP-1 Preamp,Pro-Ject Xtension 10 TT,Ortofon Cadenza Red/Nordost RedDawn LS Speaker cables, Bryston BDP-2, Bryston BDA-2,PS Audio AC-3 power cables
