B&k st2140
BKphoto
BKphoto Posts: 409
edited August 2014 in DIY, Mods & Tweaks
Hey everyone....I have a blown internal fuse, its never "for no reason" what should i be looking for outside of the obvious...?
there wasn't any drama, i just unpacked it and hooked it up and no left channel...
thanks, Brent
Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's
Post edited by BKphoto on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited August 2014
    It sounds like the previous owner blew it. Those blow when speaker cables get crossed when hooking up with the amp on. I would replace the fuse with exact replacement and power up without a speaker on it to see if it will hold. If it holds, power it down, hook up a speaker and try it out. I blew a rail fuse on one of my Odyssey amps doing just what I explained, it happens.
    If it blows when replaced, you got a faulty amp.
  • BKphoto
    BKphoto Posts: 409
    edited August 2014
    sounds good thanks...
  • agfrost
    agfrost Posts: 2,464
    edited August 2014
    Forgive me if this is too obvious: Be extra sure to get the correct fuse replacement value and type (slow or fast blow).
    http://www.bkcomp.com/fileadmin/content/bk_support/FAQ/fuse%20listing.pdf
    Hope it's just a fuse and nothing deeper!
    Jay
  • BKphoto
    BKphoto Posts: 409
    edited August 2014
    4 amp slow blow is what the manual says
  • BKphoto
    BKphoto Posts: 409
    edited August 2014
    OK....so new fuse in turned on let it run for about 15 mins and fuse held....So next step put it back in the system and see what happens...
  • Dennis Gardner
    edited August 2014
    I will bet you are okay to go. I think the seller, touched the speaker cable +&- together on that channel with the amp on before he turned it off. They put that fuse in for times like this.
  • BKphoto
    BKphoto Posts: 409
    edited August 2014
    I hope so.... nervous...
    although its quite nice on the inside...blew out the dust (wasn't a lot)...
    I have to hang the new front door before i can put it back (wife knows she will lose me if I do the stereo first)
  • BKphoto
    BKphoto Posts: 409
    edited August 2014
    New front door looks great...Amp, not so much...
    still no left channel....
    mother ............!
  • Dennis Gardner
    edited August 2014
    Sorry to hear that. Hope you can get it worked out as that is a really nice amp!
  • BKphoto
    BKphoto Posts: 409
    its now sitting at Bristol Electronics in Jersey....
    My patience is running a tad thin...
    msg Posts: 10,452
    How did this turn out? I have some older B&K gear myself, and wonder about repairs if it ever goes bad. Hope you got it repaired without much bother or cost. Doubly hope the previous owner didn't knowingly take you for ride.
    EndersShadow Posts: 17,698
    msg wrote: »
    I am not the OP obviously but I have some insight here...
    If I had B&K gear I'd do the following:
    1. Contact B&K for the service manuals for your gear. The B&K website lists a contact for that stuff. I recently used it to get both an Owners Manual and a Service Schematic for my B&K 200.5. The guy was very responsive to my inquiries and very helpful.
    2. I'd also look at the schematic (or have someone who knows what it means) and have them see what parts are hard to find.
    3. Once I had that list, I'd contact that same person to get contact info for places to look for those parts and buy as many as you can extra. I dont have the companies name in front of me, but he gave me a company name and phone number to contact (which I passed along to my tech).
    I say this because my 200.5 had an issue and blew a channel as well. I have a local tech whose quite skilled at repairs and with the contact info and the schematic he was able to repair the blown output transistors on that one channel. He didn't seem to think there was anything super tricky about the way the amp was put together, just time consuming taking it apart for the fix.
    For me the total cost was 140 including parts. So its NOT super expensive to repair (provided its just one channel), but my tech also let me know that some of the parts were becoming harder to find (because of the large quantity of fakes on the eBay market) so he had to pay a nice markup to get legit transistors and have them shipped from Cali. The parts cost was 40 bucks for 2 transistors and JFet's (IIRC).
    I plan to stock up on some as a just in case so I have them.
    Anyway thought I'd weigh in since I recently had a B&K repair experience.
    msg Posts: 10,452
    that is EXCELLENT information and a great recommendation. I have a couple of pieces of B&K gear. probably need to find a good local repair guy. how does one determine whether a repair shop is good? guess that's tricky.
    msg wrote: »
    I worked through my local trusted contacts to find one. Thankfully a couple guys I know and trust had used this person before for some stuff and his name was one I had heard a couple different times.
    This guy builds custom tube amps and repairs a lot of vintage hi fi (tube radio's, keyboards, turntable's, etc). It is nice he's in my backyard basically otherwise not sure what I would do.
    I am sure you can send it back to them to look at repair, but since my 200.5 is 78 lbs and quite a monster that would be VERY expensive to ship it, let alone a total overhaul on it.
