Cheap AM/FM Tuner
xsmi
I'm looking for a cheap AM/FM Tuner. Something in the $20.00 or less range.
2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
Post edited by xsmi on
What about this one?
http://www.ebay.com/itm/JVC-Model-T-X200-FM-AM-Vintage-Quartz-Synthesizer-Stereo-Tuner-Tested-Working-/380788111007?pt=US_Radio_Tuners&hash=item58a8bd769f
One thing that you might want to bear in mind is that the shipping costs for you tuner may cost just as much as the tuner itself. You may be able to get more bang for your buck if you checked out a local thrift store or your local used audio gear store, if you have one.Paradigm 11seMkIII mains, w/ Zu Audio jumpers
Paradigm CC 450 center, w/ Zu Audio jumpers
Polk Audio RTi6 surrounds
Paradigm SE sub
Sony BDP S5100 blu-ray player
Panasonic 50" plasma
Yamaha RX A1000 receiver
Parasound HCA 1205A amp
Audioquest Evergreen IC's -
That's what I thought about as I looked at that listing. $22 for the tuner, $15 for shipping. I've got some time today. I may do that. I just want to listen to a couple of NPR statins in the area on the main system.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
If you have a smart phone download iheeart radio, you can ( with a mini plug to RCA cable connect to any aux input of your pre and het npr without issuee and cost.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
That's what I thought about as I looked at that listing. $22 for the tuner, $15 for shipping. I've got some time today. I may do that. I just want to listen to a couple of NPR statins in the area on the main system.soundfreak1 wrote: »If you have a smart phone download iheeart radio, you can ( with a mini plug to RCA cable connect to any aux input of your pre and het npr without issuee and cost.
Or a dock. IDK if it will work but I play Pandora through my PS3 and or Xbox360. If you have one of those or any internet ready device hooked up you should be able to make them do Iheart radio.HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
Additional projects: RTA 12c's -
That's what I thought about as I looked at that listing. $22 for the tuner....
What $22 for the tuner? When I clicked the link, it was priced at $10.99 OBO. -
Get thee to a Goodwill. Try to find an old Technics (rack system refugee) for $5 or so. Stick a wire antenna on it. And your off to the races.
I actually have an iPad that I can do the iHeart radio thing with. The stations actually may be clearer that way. Thanks guys. mark this thread closed! Oh and btw, the first link was to an Onkyo not JVC. I don't know where that link went.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
I actually have an iPad that I can do the iHeart radio thing with. The stations actually may be clearer that way. Thanks guys. mark this thread closed! Oh and btw, the first link was to an Onkyo not JVC. I don't know where that link went.[/QUOTE
That one's on me. I edited the link after I first posted it because I found a cheaper tuner than the first one I posted. Sorry for the confusion.Paradigm 11seMkIII mains, w/ Zu Audio jumpers
Paradigm SE sub
The signal will be much better with iheart than the FM tuner and only cost you the cable cost ( about 10.00) good luck!Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
