Hyperion HPS-938 Floorstanders
hochpt21
hochpt21 Posts: 5,423
edited August 2014 in Speakers
Let's try this again...the Phils got away.
Has anyone ever heard of these speakers...let alone gotten ears on them?
There is a pair locally, and again, I sent the seller a message so we'll see.
Frequency Response: 30 Hz to 22k Hz
Sensitivity: 90 dB
Impedance: 6 ohms, 3.8 ohms Minimum
Power Requirement: 10 W Minimum, 200 W Maximum
Woofer: 8” P.P. Graphite S.V.F. Woofer x 2
Midrange: 6-1/2” Carbon Fiber, S.V.F. M.F.D.S. Driver
Tweeter: 1” Silk Dome, Copper Short Horn Type
Crossover: 230 Hz, 3k Hz
Finishes: Black Piano High Gloss (HPS-938)
Birdeye Maple (HPS-938W)
Dimensions:
Upper Cabinet H390 x W300 x D365
Lower Cabinet H650 x W300 x D465
Weight:
Upper Cabinet 25.3 lb (Unpacked) 30.8 lbs(Packed)
Lower Cabinet 63.8 lb (Unpacked) 70.4 lbs (Packed)
Hyperion's unique driver research has led to the cabinet design for the first HPS 906 nearly a decade ago. The duo-cabinet design was created for our full-range 3-way speaker HPS-938. HPS-938 design was completed in 2003, which includes all the features of Hyperion speaker design.
With a dedicated cabinet for the bass and all the qualities of HPS-906, the HPS 938 simply has elevated the HPS series to an astonishing new level. Two 8" S.V.F. woofers are used instead of a larger size woofer for the bass speed, resolution, coherence and impact. The New HPS-938 is our answer to a new level of audio experience.
938.jpg 62.8K
Post edited by hochpt21 on
  • chumlie
    chumlie Posts: 8,658
    edited August 2014
    Go get em baller.
  • hochpt21
    edited August 2014
    Been wanting to upgrade 2-channel speakers for awhile and found a few locally that may fit the bill.
    These look to be high eff, so maybe tube amp down the line. Or maybe the dared and the b&k.
    Gotta listen to them first.
    Generally good reviews, but a few people say they don't like the "horn" tweeters.
  • chumlie
    edited August 2014
    A few others love horn tweeters. Best to give em a listen.
  • marvda1
    marvda1 Posts: 4,952
    edited August 2014
    the only problem with these is if you need a replacement driver you're out of luck.
    Puritan PSM156
    pitdogg2 Posts: 27,077
    edited August 2014
    chumlie wrote: »
    silk dome Horn Loaded there's a big difference.
    Look an awful lot like Wilson Watt puppies
    edited August 2014
    You're right, P2. I was going to say they look like "Wilson wannabes"!
    But the question is: what do they sound like?
    cnh
    EndersShadow Posts: 17,707
    edited August 2014
    If you end up parting with your LSi 15's, hitup daboyz.... think he's toying w/ the idea of a LSi HT.
