Low Power or High Power?
  • Nightfall
    Nightfall Posts: 10,083
    edited August 2014
    Preamp out goes to an amplifier, yes you can attach an amplifier to the NAD.
    afterburnt wrote: »
    Village Idiot of Club Polk
    edited August 2014
    NFall is right. You can BYPASS the NAD's internal amps and use the receiver as a Pre-amp with ANOTHER even more powerful amp. But in that case you are NO longer using the POWER from the NAD. You're disconnecting it!
    cnh
