Speaker Cables + Interconnects - affordable/moderate entry to hear the difference?
msg
msg Posts: 10,452
Hey guys,
okay, so my curiosity is getting the better of me on the cable front, and I'd like to give this a shot to try to determine for myself whether this really makes a worthwhile difference to the listening experience for me. I'm not trying to come across as a skeptic here, but being relatively new to this, it's a little confusing when you see firm, logical positions from both sides of the argument. I'm open to the idea, and it makes sense to me.
I've been poking around here and there in searches this past week, but haven't had much time to dig in due to work obligations, so I haven't really taken in anything definitive as far as quality brands and such, or expected cost.
What I'm looking for is some moderately affordable brands/models that I look into trying out in order to determine for myself whether this contributes in a significant way to the sound quality in my system. by significant way, I mean, conveying in a better way than cheap stranded 12ga wire, rich, full, warm sound. this is what good cables are supposed to do, correct?
It's been an interesting journey so far since beginning this last winter, but much of it was frustrating and overwhelming in the beginning. I'm now feeling fairly well settled with some Parasound gear (Halo C2 w/HCA-2205) and a pair of Polk 2.3TL's. This setup sounds better than anything I've had yet, to date, but I'd like to make sure I'm getting the most out of everything.
I saw some MIT cable interfaces for about $37k. I'm gonna say here that those are just a tad more than I'd like to spend :)
what are some brands/models you guys might recommend to get me started? 6-10ft on the speaker cables will suffice, bi-wire on one end, possibly, if that's a recommended practice.
thanks in adv.
Post edited by msg on
«13
    gudnoyez Posts: 8,161
    edited August 2014
    I got signal cable set up on my HT from Signal speaker cables for L/R & center channel, Signal IC's and a Signal magic power cord, good bargain cables and real happy with them. On the 2 Channel I got MIT Terminator II speaker cables and IC's those were a bargain used, if you can't find any of these used and have to settle for something new at a reasonable price check out Signal.
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited August 2014
    Signal Cable, Blue Jean Cable, for solid small companies that give good value. Audioquest for a better know brand with wide range of offerings.
    MIT, Kimber for the lottery winner in you.
    tonyb Posts: 33,072
    edited August 2014
    Eh...there's hundreds of brands to choose from. Thing with cables is finding that synergy with the rest of your gear, and ears. You have to subscribe to the fact that you will have to kiss a few frogs before finding your Prince....so to speak.
    Buy used....your buck will buy much more cable that way. For local store bought brands, Audioquest has to be on the short list. Used, the world is your oyster. Kimber is good, older MIT, Analysis plus, PFN, Grover, Reality cables, Silnote, etc.
    Keep in mind what sounds good on someone elses system may not on yours...or to your ears. You don't have to spend a small fortune to get better sounding cables.
    msg Posts: 10,452
    edited August 2014
    excellent, guys, thanks for all the info so far. not opposed to buying used, in fact, don't particularly plan to buy anything local.
    found some interesting reading on Audioquest's site earlier in the week
    http://www.audioquest.com/theory-education/
    http://www.audioquest.com/wp-content/uploads/2012/01/DoNoHarm-whitepaper-1222-11-r11.pdf
    aren't there a couple of guys we know here who make cables that are supposed to be pretty good, too?
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    edited August 2014
    Some of the guys swear by Douglas cables.
    http://www.douglasconnection.com/
    Dan
  • erniejade
    erniejade Posts: 6,321
    edited August 2014
    Used or check dougs cables out. Shoot him an email or call him. Tell him your gear and what kind of sound your trying to get. The quality of his workmanship is awsome!
    F1nut Posts: 51,787
    edited August 2014
    You can buy MIT Shotgun S3's from Joe Abrams on Audiogon for WAY less than that. Might be the last cables you buy.
    msg Posts: 10,452
    edited August 2014
    thanks for all the recommendations guys. I'll check into all of these. I didn't realize some of this stuff could really be had somewhat "affordably" - even those MIT's.
    so it's really just occurred to me - duh - that I should be looking at all my cables and not just the speaker ones.
    is this something I can piece-meal a little at a time? should I do it this way to determine what I'm gaining, or is this something I should be doing all at once at my level of system building?
    tonyb Posts: 33,072
    edited August 2014
    I would say do it a piece at a time, speaker cables, then IC's, maybe a digital coax if you use one. That way you can attribute any pluses or minuses to a particular cable.
  • steveinaz
    steveinaz Posts: 19,545
    edited August 2014
    I like Kimbers "budget" stuff, that may well be the last cables you need; Kimber PBJ IC's and 4TC speaker cable. See also their cheaper lines that have the same topology (PR and VS I think).
    While I really like Audioquest, their IC's need to be handled with care as they are solid copper conductors, and can sometimes break from flexing too much---I speak from direct experience.
  • Monster Jam
    Monster Jam Posts: 919
    edited August 2014
    Check the website of transparent below.
    http://transparentcable.com/special/
    I'm not sure if I want to laugh at the absurdity, or get angry...
    Do you hear that buzzing noise? :confused:
  • Monster Jam
    edited August 2014
    well...yeah.
  • Willow
    Willow Posts: 11,233
    edited August 2014
    Let me look through my box at home. If I have anything decent and above, I'll let you know. If that is the case, I'll ship them to you for free. I know I have ICs and do not have speaker cables. My wife will be really happy that I'm cleaning up that "mess".
    EndersShadow Posts: 17,705
    edited August 2014
    steveinaz wrote: »
    I agree steve. Though the TC line gets a bit pricey depending on if you need jumpers or bi-wire. I've been running 8VS (bi-wire on speaker end for my LSi front 3) and love the wire. I may try 4TC for the Infinities.
    PB&J interconnects are cheap and solid.
    I too have had a experience with Audioquest IC's breaking causing a crazy ground loop like hum....
  • Willow
    edited August 2014
    MSG,
    I have :
    1x 3ft Audio Quest Component cable
    2x 6ft Acoustic Research Pro II digital audio cable
    1x 6ft Acoustic Research Performance series digital audio cable
    1 pair of 3 ft Monster Interlink 300 mkII Interconnects
    2 pairs of 3ft Acoustic Research performance series interconnects
    1 12ft brand new still in bag Acoustic Research Pro II Optical Cable
    1 pair 2ft Signal Cable (not sure which model) INterconnects
    if any, or all sound interesting let me know.
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited August 2014
    You have nice amp and speaks, what is your source's this may ( depending on what you have ) give you more bang for the buck than cables at this point. Please list your source equip! As far as cables go , mit and audioquest I use do make a diff. However if you use cd's an external DAC will have more of an impact than cables at this point ( again depending on what you use as a source) lastly bi-wire is a waist of time (especialy if only using one end) if you are going to split your signal go full biamp or dont mess with it. ( using an external xover)
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • voltz
    voltz Posts: 5,384
    edited August 2014
    Soundfreak1
    So you feel its best to use jumpers instead of bi-wire cables? ....cause I notice that a lot of times the cost of upgrading a speaker cable to bi-wire cables is about the price of just buying good jumpers. just curious on your thoughts!
  • soundfreak1
    edited August 2014
    voltz wrote: »
    Soundfreak1
    I see (or hear) no advantage to biwireing at all not that one way is better than another.if you are going to biamp (with external xover) now you are going to be doing something to improve the sound,I do not believe there is any real audable improvment in biwiring with jumper or a cable just a placebo effect at best. Imho and experience.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • BlueFox
    BlueFox Posts: 15,251
    edited August 2014
    I suspect any improvement will be proportional to the quality of the speakers and associated gear (electronics and cables). I added Shunyata VTX-11 jumpers to my Aerial Acoustics 7T speakers, and the improvement was immediately obvious. I felt it was a worthwhile upgrade to help get the best performance from my speakers. In fact, since I recently moved those speakers into my HT as the fronts, I just bought another pair of the VTX-11 jumpers for the PSB Synchrony One rear speakers.
  • pwilson2
    pwilson2 Posts: 3
    interconnection for sda2 wanted ,iapreciated your help .thanks
    BlueFox wrote: »
    msg Posts: 10,452
    Gosh, I was just a little guy back in 2014...
  • leftwinger57
    leftwinger57 Posts: 2,917
    I can't believe how long this thread has come and gone and w/ each a new hopefully a rewarding experience. For me the poor hard headed dude who refused to think a hundred $ 100 a foot cable can be better than the 12 gu Rodger Russell has famously said. I went from tarnished green oxidized 16 gu speaker cable to progressively getting better of the pack. I now use for speaker runs BJC Belden 12 gu w/ bananas ends. for I/Cs I used donated clear thin little pairs from P-MAN from Adcom to pre/amplifier w/ VERY GOOD ENDS.>from Tony, Audio quest double snake headed for cdp.pre, for tt used what is there and not reversible and from tuner/audio out from AVR w/ DCH Labs> tuner in on the pre/amp. It all works and better than the gimmies in the boxes from the cdp or other devices. Short story end all matters how much so it's up to you.
  • kevhed72
    kevhed72 Posts: 5,146
    Jesse nailed it earlier in the thread....MIT Shotgun series may be the last cables you ever buy....and snagging some used S1 or S2s is the way to go. I'm now working on upgrading my power cords to PS Audio and suspect my current power conditioner may be next to go, but more testing is needed to confirm that one.
  • Speedskater
    Speedskater Posts: 495
    Using 'MIT Shotgun' and 'affordable' in the same thread is an oxymoron.
    tonyb Posts: 33,072
    Not Really....some could say the same thing about Polk LSIM's. Everything is relative to the individuals wallet.
  • kevhed72
    Carefully comb the used market, this site in particular, and there are deals to be had on Shotgun series.
  • MrBuhl
    MrBuhl Posts: 2,419
    +2 / +2 - there are definitely deals to be had if you're patient & vigilant on the MIT's @kevhed72 is right - absolutely for a fraction of list if you look. As is @tonyb - it's all relative. I started by using what I consider to be very good upgraded cable that I could afford. Now, what I would have considered expensive cable then, I now can afford and I use. And there's nothing wrong with that IMO, in fact, that's what makes this a great hobby. I was happy with the old, but I'm happier with the new. It's all relative. That's not just true of my cables, but my speakers, my CD players, my turntables, everything in the rack. (well, except the racks, those are the same damn cheap $40 recycled wood flexys - I focused my energy elsewhere!)
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • Speedskater
    edited May 2016
    tonyb wrote: »
    Speedskater wrote: »
    Well your viewpoint of reasonable & affordable is very different than mine.
    But if I the had money to afford MIT cables, I would still stick with Blue Jeans Cable.
    F1nut Posts: 51,787
    Is that because you've tried MIT Shotgun cables and didn't like them or something else?
  • Speedskater
    Something else.
