Fixing Old Speakers
killadaclown
killadaclown Posts: 23
edited August 2014 in Vintage Speakers
I have a pair of old Polk speakers. I don't remember what they were, but I remember that when I was looking them up they were from the late 80's. They are 3-way speakers. They were used as our party speakers in college, so naturally got a lot of abuse! Unfortunately, both of the woofer cones ripped just after I finished up college and moved away from that scene. The mids and tweeters are just fine though.
Anyways, I would like to put a working woofer cone in there so that I'm able to use the speakers again. Not looking for anything fancy, but just something to throw in the garage that I could use when working on the cars or outside.
Any suggestions on how I would go about doing this? Or would it be less expensive just to buy a cheap used pair off craigslist?
Post edited by killadaclown on
  • Dabutcher
    Dabutcher Posts: 2,606
    edited July 2014
    If you are talking about the foam or rubber surrounds? Kits for replacement can be found on Ebay. Midwest speaker sells there or go to their website. They are good at helping you find the right kit. Good luck. D
  • xjghost
    xjghost Posts: 1,115
    edited July 2014
    Pictures of the speaker would help identify them and help to get you started. Some even have the model number on the back on a tag.
    HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
    Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
    Additional projects: RTA 12c's
  • Pastor Bill
    Pastor Bill Posts: 130
    edited July 2014
    I imagine that you would want to start with identifying what they are. Check for the i.d. badge on the back if it still exists. Then contact Polk via this website and see what is available. That's assuming that you want to restore them to original condition. If not, get the technical info off your torn woofers and purchase a woofer that matches or is very close. There are numerous replacement speaker vendors on the internet, such as Speaker Exchange or Parts Express or Simply Speakers. Would it be less expensive to buy a cheaper used pair off Craigslist? Probably, depending on your tastes and availability.
    The telling statement is that you just want something to throw in the garage...at that point, you're using them a background music and not critically listening, so that expands your options.
    Jesus said "I am the Way, the Truth and the Life. No man comes to the Father but through Me." - John 14:6
    NAD 7140, Fried Model Qs, Pioneer PD-4700
  • westmassguy
    westmassguy Posts: 6,850
    edited July 2014
    If they were late 80s vintage, they're not 3way, they're two way, with a passive radiator. If it's the passive radiator that's torn, Polk doesn't stock replacements, you have to search eBay for the correct passive for your model. Photos, and model # will help.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • killadaclown
    edited July 2014
    Ok thanks for all the quick responses. I will take pictures tonight after work and will post them, so then you can see what it is. And hopefully that will help narrow down the ideas to whether it would be financially worth it.
    And thank you for the websites to look for the replacement parts.
    F1nut Posts: 51,783
    edited July 2014
    Polk did not and does not use foam surrounds. There are no rubber surround kits for Polk drivers, nor are there any aftermarket replacement drivers that are suitable. Polk does stock quite a number of the proper drivers.
  • westmassguy
    edited July 2014
    They did use foam on the mini monitors in the 70s. The little 4.5" CTS drivers
    tonyb Posts: 33,072
    edited July 2014
    It would be less expensive to just buy a cheap pair of speakers off craigslist. Plus who knows what else has been damaged in the time they sat idle.
    F1nut Posts: 51,783
    edited July 2014
    Doesn't count. :biggrin:
  • westmassguy
    edited July 2014
    OK be that way :)
  • killadaclown
    edited August 2014
    Ok I had to wait to get to work before I could shrink the pictures I took.
    I haven't looked at them in a while, but first they are actually 4-way speakers and not 3-ways like I originally mentioned. Also, I guess they ended up being Pioneers, but I assume the same thing is going on.
    You should see a picture of the label, the speaker itself, and then the damaged driver. It is actually the top mid that is damaged.
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited August 2014
    I doubt seriously if the cost of repair would be worth it as the value and sound would be far less than restoration costs. Jmho.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • westmassguy
    edited August 2014
    Re-cone costs can be much higher than the speakers are worth.
  • killadaclown
    edited August 2014
    Ok sounds good. Thanks for the help and thoughts. And it's not like I'm attached to these or anything. They were just fun at the time.
  • skrol
    skrol Posts: 3,452
    edited August 2014
    The dome could possibly be pulled out with some tape. Stick the tape (not too sticky) to the dome without pushing it in farther and pull. You may need to do this repeatedly. Also a vacuum may help if you can control the suction.
    Worst case, you can buy replacement domes pretty cheap.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Schurkey
    Schurkey Posts: 2,122
    edited August 2014
    First Guess: The pushed-in dustcap won't hurt a thing. Connect 'em and see if the drivers work. If they do, you're pretty much ready to rock unless you insist on upgrading the capacitors and such in the crossovers.
