Cary mono blocks
Jhayman
Jhayman Posts: 1,548
edited July 2014 in 2 Channel Audio
Thinking about picking up these amps..good price?
http://www.canuckaudiomart.com/details/649136906-cary-single-end-class-a-300b-se-mono-blocks/
Anything I need to know, these are only 15W and my speakers are 18W
Post edited by Jhayman on
  • Jhayman
    edited July 2014
    Thanks DSkip...
    That's the problem I don't know if they are a good match for my Casta's without listening to them, but he lives about 90min away and I'm sure he won't bring them over for me to try out.
    I'll keep thinking about it I'm on vaca after next week so maybe a present to myself if they are still avail next week, lol
    edited July 2014
    I'm a fan of the Cary "sound" so I may be partial but if you can have the dude give you an audition on his system before you buy, that would go a long way.
  • Jhayman
    edited July 2014
    Hey Tony, that's all fine and dandy but that only shows me how good they match HIS speakers..
    I've never heard any Cary gear before..and from what I've read and people telling me SET amps are picky about speaker matching impedance.
    tonyb wrote: »
    edited July 2014
    Yeah, they are pal, just take note of his gear is all. Your speaks should pair up well and let that Cary sound shine threw. The only part I would pay attention to, and that's just me, is the lower bass notes. Some can do them well, fast, while others are a tad more rounded, slower sounding. Cary tends to sound a tad more rounded than some but less than others in that department. Still, their midrange and highs, separation and soundstage is to die for in my opinion. All depends on your ears and what makes your nuts glow in the dark.
    F1nut Posts: 51,894
    edited July 2014
    Can you take your speakers to his house?
    txcoastal1 Posts: 13,514
    edited July 2014
    IMHO, I think it would be a wonderful combo
    but I would start my offer at $1600
    edited July 2014
    thats the best idea since they are bookies
  • Jhayman
    edited July 2014
    They are Sold...
    Or I was seriously thinking of bringing my speakers over..
    Perhaps it was a good thing as I'm very very Happy with my system and just can't seem to stop the upgrade bug..lol
    edited July 2014
    Jhayman wrote: »
    They are Sold...
    I figured it was the bug that was biting as your gear list looks tasty
    There will be another pot of gold at the end of the rainbow
  • Jhayman
    edited July 2014
    Or these ones...
    http://www.canuckaudiomart.com/details/649123922-cary_cad50_mark2_kt88_monoblocks/
    What do you guys and gals think, A Big Yes or No or are you f'ing Crazy..?
  • boston1450
    boston1450 Posts: 7,758
    edited July 2014
    Yes beautiful-Yes your crazy :smile:
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
    edited July 2014
    Since he's offering an audition, see if you can take your speakers. Easy to tube roll. You can swap to 6550's which in some designs will give a little more bottom end.
    edited July 2014
    Don't think you can go wrong either way. If these will be your first tube amps, keep in mind some concerns. They can act as space heaters....some of them anyway. You need to keep check on the bias of the tubes, unlike a tubed pre amp. If you have small children around, it may not be ideal. As noted in another thread, leaving a tube amp on and alone can open you up to a disaster should a tube go south.
    If you can deal with that, then the rewards may out weigh the small concerns.
  • voltz
    voltz Posts: 5,384
    edited July 2014
    Having got a tube amp for the 1st time I surprised at the weight, and it really is a space heater. and biasing the tubes isn't no fun with a meter in one hand and a wrench in the other, BUT!! its been worth it to me :)
    Take heed of all the warnings, like always having speakers hooked up etc...
