How big of a deal is this?
Guess this comes with the territory when you pick up RTI A7s off Craigslist for $325...but how big of a deal is this? does this effect sound? If so, how do I go about fixing it?
Post edited by wahoosboy on
If your worried about the little dent? Don't sweat it, it's not hurting anything..
I'm not sure if that is from being pushed in or if the tweeter overheated. Anyway, you can order a new one from Polk. Simple repair, unscrew the 2 hex head bolts, the tweeter assembly pops out, pull the leads, reverse.Political Correctness'.........defined
President of Club Polk -
It does look like heat to me too Jesse.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Well, first thing is how does it sound? I'm assuming you got 2 so if the other one is ok compare the 2 for sound and go from there.Anaheim Hills CA,
2 Channel: Rogue RP-5 / WireWorld Electra power cord / Marantz TT-15S1/ Ortofon - Quintet Black MC / Marantz NA8005 DAC / W4S mAmp's / Synology DS 216+ll-4TB / Polkaudio LSiM703 -
Even if it needs to be replaced $350 for a pair of cherry A7s is a pretty good deal!Home Theater
Yeah, I was happy I came across this bargain. There doesn't seem to be a difference in treble from the other speaker. I'll probably just live with it for now. However I'm curious, do you know what Polk charges for a new tweeter?
It probably won't impact the sound from a practical sense. It may change the dispersion pattern slightly but it looks like it would be in an extremely off-axis area where it wouldn't matter. If it bothers you, might try a little adhesive tape to gently pull out the dent.Stan
Main 2ch:
HT:
Other stuff:
I found my RTA 12s in the dump (literally) and one of the Peerless tweeters had slight creases and the other Peerless had 3 really defined creases.
Took em home and w/i 20 min they were sounding great. Had a slight decrease in output on the heavily creased tweeter but a slight balance adjustment fixed it. I'll eventually get the replacements (from Madisound I think) but as long as they sound this good I can live with it.HT: Marantz NR-1603, Oppo 981, Def Tech SM55, SVS PB-1000
BR: iPad Mini, Audio Engine A5+
2C: Parasound ZDAC V.2, Sony DA80ES, Sony XDR-F1HD, SVS Prime Tower, JSE .6 Infinite Slope
Office: MBAir, Focusrite Scarlett 2i2, JBL LSR-308
Projects: Polk RTA12, Polk Monitor 7, Revox B225CD, BIC 3-TM -
Why would'nt you get them from Polk?OldSchoolPolk wrote: »I found my RTA 12s in the dump (literally) and one of the Peerless tweeters had slight creases and the other Peerless had 3 really defined creases.
Took em home and w/i 20 min they were sounding great. Had a slight decrease in output on the heavily creased tweeter but a slight balance adjustment fixed it. I'll eventually get the replacements (from Madisound I think) but as long as they sound this good I can live with it.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
+1 , real sweet deal. Put the grills on. Problem solved.Even if it needs to be replaced $350 for a pair of cherry A7s is a pretty good deal! -
hook them up to your computer (through receiver), play some chimes, bells, and other high frequency samples with the balance switched completely 100% left, then right. You should be able to notice if there is a problem.
PolkieMan. Why would'nt you get them from Polk?
I thought Polk only made RDO 194/8 for their 1000-2500 tweeter series. They don't make a replacement for the Peerless.HT: Marantz NR-1603, Oppo 981, Def Tech SM55, SVS PB-1000
My brothers son pushed both of mine in one day. They don't sound any different, but they just look weird. I wasn't to happy about it...
