Power Amp Stands
gudnoyez
Looking for a place to buy a Amp Stand an inexpensive one at that, say one around 200 bucks if something exits in that price range. I was wondering if cutting a sheet of plywood the size of the amp would work and what to use for isolation feet. Leads anyone?
Post edited by gudnoyez on
Audio Advisor has some to look at! I buy a lot of stuff from them.
http://www.audioadvisor.com/Amp-Floor-Stands/products/37/
The black one has our Adcom 5503 sitting on it LOL!2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
It appears that that black sanus is the way to go you got a 5503 sitting on yours the picture of the one in the display has a 5503 on it a d that's what I'm looking to put my 5503 on. Let me ask you this does it have spikes? I put down a floating floor system it's tile on a plastic frame carpeted it's raised off the concrete floor an inch with that weight spikes would go through it unless I put hockey pucks under the spikes what do you think?Audio Advisor has some to look at! I buy a lot of stuff from them.
The black one has our Adcom 5503 sitting on it LOL!Home Theater
The VTI stuff is nice as is Lovan
I think you can find them on Amazon.My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
I don't have one yet! I just meant in the picture on there web site it looked like it was the 5503 in the pic. as I knew you & I both had the 5503 amp.
just check the manual and it does have spikes & plastic feet included.
But I think your right about the combination of the amps weight & the spikes could be a problem for you. you may want these little disc under the spikes. or just use the other feet which I think are height adjustable.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Hey thanks found it on Amazon for $66 free shipping thanks voltz you came through for me
I have used the Sanus Euro stands for about 8 years now and will be ordering a couple more to go on either side for amp stands. They are rugged, well built and easy to clean with a nice matte black surface that resists marring too. They have nice discs on the rails to protect floors.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
My Sanus Euro amp stand showed up today man Amazon is fast. I would of loved seeing it drone delivered but fast enough for me thanks for all the suggestions everyone!Home Theater
How are they working out for you? and have you got all of your equipment hook up now?2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
